Graphics on Cisco Nexus Do Not Display Properly
in SAN
Hello everyone,
We are monitoring 4 Cisco Nexus servers, its configuration was very simple, however, the graphics referring to the ports, either ethernet or SAN the graphics are displayed with a strange appearance.
An image is attached to the post to demonstrate.
Any suggestions for what might be going on and some way to fix it? Thanks so much for any help. Rafael
are all ports affected or just some ports?Send us logs pls.Note a short problem description in the text field of the upload form.cd /home/stor2rrd/stor2rrd # or where is your STOR2RRD working dir
Log files sent.
Answering your question, All graphs on all nexus switch ports are displayed this way. -
data collection from your switches takes too long. Especially from this switch DC2-N5K-A.
Can you try the following steps? It should help.
1. increase data collection timeout
Just put line "export SAN_DATA_COLLECTION_TIMEOUT=900" to etc/.magiccd /home/lpar2rrd/stor2rrd
echo "export SAN_DATA_COLLECTION_TIMEOUT=900" >> etc/.magic
2. re-schedule the crontab for SAN agentcrontab -e Change this line:
0,5,10,15,20,25,30,35,40,45,50,55 * * * * /home/lpar2rrd/stor2rrd/load_sanperf.sh >/home/lpar2rrd/stor2rrd/logs/load_sanperf.out 2>&1
to:
0,10,20,30,40,50 * * * * /home/lpar2rrd/stor2rrd/load_sanperf.sh >/home/lpar2rrd/stor2rrd/logs/load_sanperf.out 2>&1Let it work about 2-3 hours and let us know if that helped.
Hi Karel, The graphics are now displaying perfectly. Thanks a lot for the help. Rafael
- 115 XorMon
- 174 LPAR2RRD
- 140 STOR2RRD
