load.sh issue with CPU-CORE rrd creation
I'm trying to run load.sh for the first time and getting this error w/ stor2rrd 2.01
RRDp::create read error : /usr/local/home/lpar2rrd/stor2rrd/data/xx/CPU-CORE/netapp1clus1-01 -processor0.rrd : ERROR: unknown option 'p' at bin/Xorux_lib.pm line 61. : No such file or directory
create_rrd err : unable to create /usr/local/home/lpar2rrd/stor2rrd/data/xx/CPU-CORE/"netapp1clus1-01 "-processor0.rrd (filesystem is full?) at bin/LoadDataModule.pm: line 1273
looks like it's trying to add an extra space in the middle of the filename
in the config.html there is a space after cluster name like this
Hostadapter Level Configuration
name,node_name,node_uuid
0a,"netapp1clus1-01 ",
0b,"netapp1clus1-01 ",
CPU-core Level Configuration
cpu,node_name,node_uuid
processor0,"netapp1clus1-01 ",
processor1,"netapp1clus1-01 ",
any idea how to fix this?
ok, I see the problem, your node name contains a space. This would not be a problem, problem is double quotes.
Fix:
1. install the latest 2.01
2. get this fix:
http://www.stor2rrd.com/download/LoadDataModule.pm.gz
Gunzip it and copy to /home/stor2rrd/stor2rrd/bin (755, stor2rrd owner)
-rwxr-xr-x 1 stor2rrd stor2rrd 801704 Jun 15 09:53 bin/LoadDataModule.pm
If your web browser gunzips it automatically then just rename it: mv LoadDataModule.pm.gz LoadDataModule.pm
let it work, the error should disappear.
Let us know, we have not simulated it but it should work.
thanks but no luck yet. we have checked and there does not appear to be a space at the end of the node name on the netapp.
however some commands for example "system node show" do add a space in the output. I think the part of stor2rrd that initially reads into %netapp hash needs to trim the node name and remove any quotes or spaces, although I could be wrong.
I have checked some other netapp arrays and they all produce this extra space after node name even though it's not actually part of the name..
from /usr/local/home/lpar2rrd/stor2rrd/load_netappperf.sh:
Argument ""a8f2d8ca-eaa5-11e4-a465-459d56f1691 "" isn't numeric in division (/) at /usr/local/home/lpar2rrd/stor2rrd/bin/naperf.pl line 837.
Argument ""d5ff1992-eaa5-11e4-8e7-d71363c1ed30 "" isn't numeric in division (/) at /usr/local/home/lpar2rrd/stor2rrd/bin/naperf.pl line 837.
Use of uninitialized value $RRDp::error_mode in string eq at /usr/lib64/perl5/vendor_perl/RRDp.pm line 168, <FH> line 431.
ERROR: /usr/local/home/lpar2rrd/stor2rrd/data/xx/CPU-CORE/netapp1clus1-01 -processor0.rrd: conversion of '- ' to float not complete: tail '- ' at /usr/local/home/lpar2rrd/stor2rrd/bin/LoadDataModule.pm line 16740.and load.sh:
xx : load_host failed: ERROR: /usr/local/home/lpar2rrd/stor2rrd/data/xx/CPU-CORE/netapp1clus1-01 -processor0.rrd: conversion of '- ' to float not complete: tail '- ' at bin/LoadDataModule.pm line 16740.
./bin/storage.pl:186 -
if this helps here is how node_name strings are stored in the cache file:
'netapp1clus1-01:clus2' => {
'node_name' => '"netapp1clus1-01 "',
'vserver_name' => '"netapp1clus1-01 "',they have double quotes and a space as part of the string. many occurrences of the same bad string. this must be how it's returned from the netapp
I got the above info from this code
#!/usr/bin/perl -w
use strict;
use Storable;
use Data::Dumper;my $netapp=retrieve('xx.cache.file');
print Dumper($netapp);
thanks, we will provide a fix soon. Double quotes causing a problem, looks like they are even in UUID string.
@jjsk1:
could you please provide us with some degug data? Please follow these steps:
Activate data collection:su - stor2rrd cd /home/stor2rrd/stor2rrd echo "export KEEP_OUT_FILES=1" > etc/.magic echo "export DEBUG_FULL=2" >> etc/.magic
Wait for 15 minutes, then send us data for analysis (via https://upload.stor2rrd.com):cd /home/stor2rrd/stor2rrd tar cvf dump.tar data/YOUR_FILER_NAME/*perf* \ data/YOUR_FILER_NAME/*conf* \ data/YOUR_FILER_NAME/*.dump gzip -9 dump.tar rm etc/.magicdump.tar now should contain files like YOUR_FILER_NAME-*.cli.dump and your_filer_name-*.api.dump , that's what we need.
Don't worry, there will be no private content included.
Hi, any fix for this issue? I'm getting the same problem...
Thanks!! -
upgrade to this version till there is released new one
http://www.stor2rrd.com/download/stor2rrd-2.01-1.tar
There will be a new version 2.10 release in 2 weeks where it will be also fixed.
http://www.stor2rrd.com/note210.htm?1.8
just to finish that thread to help others ...
use this code:
http://www.stor2rrd.com/download-static/naperf.pl.gz
-rwxrwxr-x 1 stor2rrd stor2rrd 99075 Apr 12 13:50 bin/naperf.pl
If your web browser gunzips it automatically then just rename it: mv naperf.pl.gz naperf.pl
wait 10 minutes and then remove this:
rm data/<storage name>/<storage name>*
After that it will start working
