not getting perf metrics, capacity ok
I'm trying to collect metrics from a NetApp FAS, using the latest version of stor2rrd running in docker.
The stor2rrd user on the netapp side has all permissions/role configured properly.
I'm able to capture capacity metrics but nothing else, and I keep getting the same error when testing the config (see error below).
I have the same config working in 2 other sites with no issues.
Thanks for your help/suggestions!
API data test: OK
API host network connection: TCP connection to xxx.xxx.xxx.xxx:443 is OK.
Crontab test: OK
API authorization: OK
API data test: OK
SSH network connection: TCP connection to xxx.xxx.xxx.xxx:22 is OK.
SSH authorization: OK
SSH data test: OK
Connection to xxx.xxx.xxx.xxx closed by remote host. Use of uninitialized value $cmd_out in scalar chomp at /home/stor2rrd/stor2rrd/bin/na_sshtest.pl line 57. Use of uninitialized value $cmd_out in pattern match (m//) at /home/stor2rrd/stor2rrd/bin/na_sshtest.pl line 59. Use of uninitialized value $cmd_out in pattern match (m//) at /home/stor2rrd/stor2rrd/bin/na_sshtest.pl line 81. Use of uninitialized value $cmd_out in pattern match (m//) at /home/stor2rrd/stor2rrd/bin/na_sshtest.pl line 101. Use of uninitialized value $cmd_del in pattern match (m//) at /home/stor2rrd/stor2rrd/bin/na_sshtest.pl line 113. Use of uninitialized value $cmd_out in split at /home/stor2rrd/stor2rrd/bin/na_sshtest.pl line 123.
SSH data test: OK
I've just tested latest Docker image in our lab with success, send us logs please.Note a short problem description in the text field of the upload formcd /home/stor2rrd/stor2rrd tar cvhf logs.tar logs tmp/*txt gzip -9 logs.tar
Hello Jirka,
I just uploaded the logs which have been shared with me.
Thank you for the help!
