Some 3Par Arrays Not Collecting Data
Version 2.61 - Virtual Appliance
We have multiple 3Par arrays defined (20850 and 8440). 2 of the 8440's are not collecting data.
I double-checked the definitions and manually reset the pwf file with the following command:
/opt/hp_3par_cli/bin/ ./cli setpassword -saveonly -file /home/lpar2rrd/stor2rrd/etc/.3par-10.11.12.13.pwf -sys 10.11.12.13
The error logs for these arrays only show the following error over and over:
Manually running a "showuser" with the 3Par CLI works fine.
./cli -sys 10.11.12.13 -pwf /home/lpar2rrd/stor2rrd/etc/.3par-10.11.12.13.pwf showuser
When I run "config-check.sh" on the arrays, it locks up during the CLI check.
Any idea what could be wrong with these 2 arrays? Any idea what "code 255" is?
Thanks.
Tue Nov 26 10:10:10 2019 ERROR : hp3parperf.pl: Command showversion failed with code 255
Username Domain Role Default
stor2rrd all browse N
Thanks.
Hi,send us complete output ofsu - lpar2rrdcd /home/stor2rrd/stor2rrd./bin/config_check.sh <storage name>tail logs/error.log-<storage anme>tail logs/output.log-<storage name>better upload it to us due to privacy purposes
I eventually got it working. I had to add those 2 arrays to the old "storage-list.cfg" file. For HPE 3Par, some scripts must still be referencing that file.
Hi,if you have stor2rrd 2.60+ then nothing reads storage-list.cfg.Pls let us know what you have done, it is weird.
