Totals for SAN Switches are not working
I just realised today, that the Total for SAN switches are not working (Data is displayed only for 4 switches) . Data and Frame are affected. As I can see, we have this problem since July:
Individual data for all switches are there. What could be the problem? We are using stor2rrd v2.61 currently.
Zoltan
Hi Zoltan,Send us logs pls.Note a short problem description in the text field of the upload form.
Hi Karel,I have uploaded the logs.
Hi Zoltan,
you have got some strange directory called "No more variables left in this MIB View (It is past the end of the MIB tree)" in your data directory. See below. Directory was created on July 17th.======== ls -l /opt/serviced/volumes/stor2rrd/data
total 1252
drwxr-xr-x 2 zenoss zenoss 4096 Jul 17 09:33 No more variables left in this MIB View (It is past the end of the MIB tree)
Remove these files, it should help:rm -r "/opt/serviced/volumes/stor2rrd/data/No more variables left in this MIB View (It is past the end of the MIB tree)"
rm /opt/serviced/volumes/stor2rrd/tmp/san_last_up*
Let us know tomorrow if it helped, thanks.
Hi Karel,that caused the problem, Total is working again correctly.Thank you!
