capacity issue
Not sure why but in the below chart virtual size go switched which caused over subscription to be wrong,
I have looked at other charts this is the only 1 I see this issue.
03_0 virtual should be 643 GiB and 02_0 should be 1.9 TiB.
Send us logs pls.
You might even attach screenshots when it helps in understanding of the issue.
thank you
Files submitted we now see other pools with the same issue.
