Stor2rrd 2.60 Problem with graphs in dashboard
Hello
First of all thanks for such powerful monitoring tool.
My question: after upgrade to 2.60 version I cannot save graphs in dashboard. I push icon of star in right top corner of a graph, create and choose new dashboard group, then the graph appears in dashbord, but after refreshing web page it dissapears. It looks like option in demo https://demo.stor2rrd.com/?menu=ea7021f&tab=0 "DASHBOARD - demo site doesn't save changes".
Is it my local problem or bug?
First screen after upgrade
adding graph to new dashboard group
new graph in dashboard
Dashboard after refreshing page:
Hi,cd /home/stor2rrd/stor2rrdls -la etc/web_configps -ef| egrep "apache|http"
-bash-4.2$ ls -la etc/web_config/итого 160drwxrwxrwx. 2 stor2rrd stor2rrd 4096 окт 8 12:31 .drwxr-xr-x. 4 stor2rrd stor2rrd 4096 окт 8 16:23 ..-rwxrwxrwx 1 stor2rrd stor2rrd 341 окт 8 16:23 alerting.cfg-rw-rw-rw- 1 apache apache 821 окт 8 12:31 config_check_apache.log-rwxrwxrwx. 1 stor2rrd stor2rrd 60 окт 8 16:41 custom_groups.cfg-rw-rw-rw- 1 apache apache 120 сен 5 08:51 db_Dashboard1-rw-rw-rw- 1 apache apache 124175 окт 8 12:28 devicecfg.json-rwxrwxrwx. 1 stor2rrd stor2rrd 44 авг 5 16:35 htusers.cfg-rwxrwxrwx. 1 stor2rrd stor2rrd 1285 окт 8 15:22 reporter.json-rwxrwxrwx. 1 stor2rrd stor2rrd 880 авг 6 09:11 users.json-bash-4.2$ ps -ef| egrep "apache|http"apache 1033 34233 0 09:27 ? 00:00:00 /usr/sbin/httpd -DFOREGROUNDapache 5577 34233 0 окт09 ? 00:00:00 /usr/sbin/httpd -DFOREGROUNDapache 8767 34233 0 окт09 ? 00:00:00 /usr/sbin/httpd -DFOREGROUNDapache 9504 34233 0 09:39 ? 00:00:00 /usr/sbin/httpd -DFOREGROUNDapache 9949 34233 0 09:39 ? 00:00:00 /usr/sbin/httpd -DFOREGROUNDapache 10860 34233 0 окт09 ? 00:00:00 /usr/sbin/httpd -DFOREGROUNDapache 20029 34233 0 окт09 ? 00:00:00 /usr/sbin/httpd -DFOREGROUNDroot 34233 1 0 окт08 ? 00:00:16 /usr/sbin/httpd -DFOREGROUNDapache 53152 34233 0 окт09 ? 00:00:00 /usr/sbin/httpd -DFOREGROUNDapache 55690 34233 0 07:57 ? 00:00:00 /usr/sbin/httpd -DFOREGROUNDapache 57016 34233 0 09:17 ? 00:00:00 /usr/sbin/httpd -DFOREGROUNDstor2rrd 63515 63490 0 10:41 pts/0 00:00:00 grep -E --color=auto apache|htt
try this:chown apache etc/web_config/users.jsonAfter each dashboard change that file must be updated.
I tried, but nothing changed.
File users.json is not updated after any dashboard change.
Hi,these logs plsNote a short problem description in the text field of the upload form.
cd /home/stor2rrd/stor2rrd # or where is your STOR2RRD working dirgrep -v passw etc/web_config/users.json > tmp/users.txt
Pavel, thank you for your assistance with my problem. Issue is solved. The problem was really with apache. There is no built-in LDAP in Stor2rrd so I had to configure LDAP in apache conf file as recommended in manual. After this configuration users cannot change dashbord. When there is no LDAP configuration in apache Stor2rrd works properly.
