Capacity Reporting - Allocated (running 2.51)
Hi,do you mean virtual capacity, oversubscription?It is already there: https://demo.stor2rrd.com/?menu=66d12b4&tab=6
Yes, virtual capacity/over subscription. I saw that what you are referring to. But I am looking for it in the reporting section, where I can generate pool level reports on the whole environment showing used and over subscribed
Hi,your right, virtual capacity/over subscription is not in: reporter --> capacity --> CSVIt will be implemented in coming version v2.60
Thanks.
