Monitoring for HDS AMS arrays
in SAN
Hi:
I'm looking to monitor two Hitachi arrays: AMS2500 and AMS500. Are these models supported?
Sincerely,
Alex H.
Hi,basically AMS is supported except quite historical firmwares.Definitelly try it, if it does not work then let us know, we will check logs and let you know.
Thanks.I'm going through the configuration procedure:- check for libstdc++ - is there!# rpm -qa|grep libstdc++
libstdc++-4.8.5-36.el7_6.2.x86_64- installed HSMN2 CLI as per instructions - Done!- changed ownership of /usr/stonavm to stor2rrd - Done!- switched to stor2rrd and set the environment - Done!LIBPATH=/usr/stonavm/lib:$LIBPATH SHLIB_PATH=/usr/stonavm/lib:$SHLIB_PATH LD_LIBRARY_PATH=/usr/stonavm/lib:$LD_LIBRARY_PATH STONAVM_HOME=/usr/stonavm STONAVM_ACT=on STONAVM_RSP_PASS=on PATH=$PATH:/usr/stonavm export LIBPATH SHLIB_PATH LD_LIBRARY_PATH STONAVM_HOME STONAVM_ACT STONAVM_RSP_PASS PATH
- ran connection test to the array - all OK!- tried to register automatically the array (under stor2rrd or root - tried both):#auunitaddauto -ip <AMS2500_IP> - bash: /usr/stonavm/auunitaddauto: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
That means I'm missing: /lib/ld-linux.so.2How can I resolve this ?
Hi,You have downloaded 32bit package.You're on a 64-bit system, and don't have 32-bit library support installed.
To install (baseline) support for 32-bit executables
https://stackoverflow.com/questions/8328250/centos-64-bit-bad-elf-interpreter
Thank you very much!I was able to pass that step and register the array.
- 1.6K All Categories
- 91 XORMON NG
- 26 XORMON Original
- 164 LPAR2RRD
- 18 IBM i
- XenServer / Citrix
- 134 STOR2RRD
- 5 EMC
- 15 HPE
- Lenovo
