SAN switches stopped working after upgrade to 1.30
I get this error on 1.30
ERROR: start (1467072000) should be less than end (1467017582) at /home/lpar2rrd/stor2rrd/bin/san_rrdupdate.pl line 358.
Use of uninitialized value $RRDp::error_mode in string eq at /usr/lib64/perl5/vendor_perl/RRDp.pm line 168.
If i reboot the machine it works for few hours and then i get the same.
have not you got a problem with local time as it wants to do some conversion on the backed and found data rows from switch(es) with timestamp Tue Jun 28 02:00:00 CEST 2016 (what is tomorrow). -
i saw that aswell in the meantime, im trying to find out which switch is giving that error from the stor2rrd logs.Server time is ok..
I'm testing this tool on a big SAN environment, because somehow this doesn't make sence (all my switches have ntp servers configured and sync the time from them) -
what is actual status? Is it working after finished background conversion?
Pavel -
yes it was working, i've also upg to 1.31.
- 116 XorMon
- 140 STOR2RRD
