Some switches are not displayed in their fabric.
Hi everybody!
[lpar2rrd@xorux stor2rrd]$ cat etc/san-list.cfg
# SAN configuration file. All SAN switches must be listed here
# <switch IP or hostname>:<SNMP community string>:<BRCD|CISCO>:<fabric name>
# <fabric name> will be used in the GUI for Fabric aggregated graphs
# use it on ONE switch in the each fabric!!!
# <SNMP community string> is usually set to string "public". In this case you can leave it blank.
# GUI will show the real name of the switch regardless what name or IP you use here
# example (note each fabric alias is just once on arbitrary switch in given fabric!!!
# It is not necessary to put fabric alias on each switch in the fabric)
#172.32.216.10::BRCD:Fabic_A
#172.32.216.11::BRCD:Fabic_B
#172.32.216.13::BRCD:
#172.32.216.14::BRCD:
#172.32.216.15::BRCD:
# Define your SNMP port If you using another then default 161
#SNMP_PORT=161
# Brocade Network Advisor (BNA)
# <BNA IP or hostname>:<port>:BNA:<API user>:<encrypted password>:<backup BNA node IP or hostname>
# to encrypt password use: perl ./bin/spasswd.pl
# 192.168.1.1:443:BNA:stor2rrd:IT5gYGAK:192.168.1.2
10.145.151.178::BRCD:Fabric_A
172.17.36.131::BRCD:Fabric_A
10.200.205.151::BRCD:Fabric_A
10.200.205.220::BRCD:Fabric_A
172.17.36.133::BRCD:Fabric_A
10.200.205.123::BRCD:Fabric_A
10.200.205.115::BRCD:Fabric_A
172.17.36.161::BRCD:Fabric_A
172.17.36.223::BRCD:Fabric_A
10.200.205.43::BRCD:Fabric_A
172.17.36.82::BRCD:Fabric_A
172.17.36.139::BRCD:Fabric_A
10.200.205.168::BRCD:Fabric_A
10.145.151.177::BRCD:Fabric_B
10.200.205.152::BRCD:Fabric_B
10.200.205.124::BRCD:Fabric_B
10.200.205.116::BRCD:Fabric_B
10.200.205.221::BRCD:Fabric_B ### this
172.17.36.222::BRCD:Fabric_B
10.200.205.42::BRCD:Fabric_B
172.17.36.83::BRCD:Fabric_B ### and this
172.17.36.132::BRCD:Fabric_B
172.17.36.134::BRCD:Fabric_B
172.17.36.140::BRCD:Fabric_B
172.17.36.162::BRCD:Fabric_B
10.200.205.169::BRCD:Fabric_B
Help me please solve the problem. Use stor2rrd for monitoring storage systems and SAN switches.
After adding all the switches to monitoring, there are 26 of them in total, 2 switches are not in their fabric.
#SNMP_PORT=161
Hi Micallef,
are you sure these switches belongs to the fabric B?
Send us the output from the following.cd /home/stor2rrd/stor2rrd # or where is your STOR2RRD working dir
cat data/*/fabric.txt -
Hi, Karel![lpar2rrd@xorux stor2rrd]$ cat data/*/fabric.txt
10000005334AC2A0,100050EB1AFCD091,fc_sw01_Big_Daddy_16g_GA,Fabric_A
10000005334AC2A0,10000027F83C5800,fc_sw01_bl_01_GA,Fabric_A
10000005334AC2A0,10000005334AC2A0,fc_sw01_bl_01_PA,Fabric_A
10000005334AC2A0,10000027F8B52102,fc_sw01_bl_02_GA,Fabric_A
10000005334AC2A0,10000005336F1B66,fc_sw01_bl_02_PA,Fabric_A
1,1,fc_sw01_bl_03_GA,Fabric_A
10000005334AC2A0,10000027F83C57F7,fc_sw01_bl_07_PA,Fabric_A
10000005334AC2A0,10000027F82911E1,fc_sw01_brocade_TU_GA,Fabric_A
10000005334AC2A0,10000027F8290729,fc_sw01_BRSW01_PA,Fabric_A
10000005334AC2A0,10000027F8845CCA,fc_sw01_CentralSW8-80_GA,Fabric_A
10000005334AC2A0,10008894714513B0,fc_sw01_huawei_ga,Fabric_A
10000005334AC2A0,1000889471441EA8,fc_sw01_HUAWEI_PA,Fabric_A
10000005334AC2A0,10000027F8BBFEDB,fc_sw_01_lw16g_PA,Fabric_A
10008894714414A8,100050EB1AEFD096,fc_sw02_Big_Daddy_16g_GA,Fabric_B
10008894714414A8,10000027F84870EB,fc_sw02_bl_01_GA,Fabric_B
10008894714414A8,100000053349F05C,fc_sw02_bl_01_PA,Fabric_B
10008894714414A8,10000027F8B51FF3,fc_sw02_bl_02_GA,Fabric_B
1,1,fc_sw02_bl_02_PA,Fabric_B
1,1,fc_sw02_bl_03_GA,Fabric_B
10008894714414A8,10000027F83C5806,fc_sw02_bl_07_PA,Fabric_B
10008894714414A8,10000027F828D2C3,fc_sw02_brocade_TU_GA,Fabric_B
10008894714414A8,10000027F82925A1,fc_sw02_BRSW03_PA,Fabric_B
10008894714414A8,10000027F82A4A21,fc_sw02_CentralSW8-80_GA,Fabric_B
10008894714414A8,10008894714414A8,fc_sw02_huawei_ga,Fabric_B
10008894714414A8,1000889471441468,fc_sw02_HUAWEI_PA,Fabric_B
10008894714414A8,10000027F8BE32AD,fc_sw_02_lw16g_PA,Fabric_B
Hi Micallef,
Send us logs pls.Note a short problem description in the text field of the upload form.cd /home/stor2rrd/stor2rrd # or where is your STOR2RRD working dir
Hi Micallef,
it looks like the following 3 switches are not part of any fabric. They are probably in AG mode (Access Gateway).
1,1,fc_sw01_bl_03_GA,Fabric_A1,1,fc_sw02_bl_02_PA,Fabric_B1,1,fc_sw02_bl_03_GA,Fabric_B
Can you confirm if they are in AG mode? -
Hello, Karel!Thanks for the tip, I'll check it now.Karel, it can be if the expanded license is not activated on these switches?
I don't think switches license can be the cause ... But if they are in access gateway mode, they won't appear in the same fabric as other switches ...Maybe copy/paste here the result of a fabricshow ?
@mbayar, hi!I am sorry, I was on vacation, so I was delayed with the answer
Switch ID Worldwide Name Enet IP Addr FC IP Addr Name
1: fffc01 10:00:00:05:33:49:f0:5c 10.200.205.152 0.0.0.0 "fc_sw02_bl_01_PA"
5: fffc05 10:00:00:27:f8:3c:58:06 10.200.205.124 0.0.0.0 "fc_sw02_bl_07_PA"
6: fffc06 10:00:00:27:f8:29:25:a1 10.200.205.116 0.0.0.0 "fc_sw02_BRSW03_PA"
7: fffc07 10:00:00:05:33:6f:61:09 10.200.205.221 0.0.0.0 "fc_sw02_bl_02_PA"
9: fffc09 10:00:88:94:71:44:14:a8 172.17.36.222 0.0.0.0 >"fc_sw02_huawei_ga"
10: fffc0a 10:00:88:94:71:44:14:68 10.200.205.42 0.0.0.0 "fc_sw02_HUAWEI_PA"
12: fffc0c 10:00:88:94:71:6d:aa:a8 172.16.240.19 0.0.0.0 "fc_sw02_wedo_ga"
13: fffc0d 10:00:88:94:71:6d:b7:70 10.200.205.47 0.0.0.0 "fc_sw02_wedoo_pa"
41: fffc29 10:00:00:05:33:c7:c5:c3 172.17.36.83 0.0.0.0 "fc_sw02_bl_03_GA"
44: fffc2c 10:00:00:27:f8:28:d2:c3 10.145.151.177 0.0.0.0 "fc_sw02_brocade_TU_GA"
100: fffc64 10:00:50:eb:1a:ef:d0:96 172.17.36.132 0.0.0.0 "fc_sw02_Big_Daddy_16g_GA"
101: fffc65 10:00:00:27:f8:2a:4a:21 172.17.36.134 0.0.0.0 "fc_sw02_CentralSW8-80_GA"
102: fffc66 10:00:00:27:f8:48:70:eb 172.17.36.140 0.0.0.0 "fc_sw02_bl_01_GA"
104: fffc68 10:00:00:27:f8:b5:1f:f3 172.17.36.162 0.0.0.0 "fc_sw02_bl_02_GA"
169: fffca9 10:00:00:27:f8:be:32:ad 10.200.205.169 0.0.0.0 "fc_sw_02_lw16g_PA"
209: fffcd1 10:00:00:05:33:a6:b4:7a 10.200.205.126 0.0.0.0 "fc_sw02_bl_09_PA"
The Fabric has 16 switchesSwitch ID Worldwide Name Enet IP Addr FC IP Addr Name
1: fffc01 10:00:50:eb:1a:fc:d0:91 172.17.36.131 0.0.0.0 "fc_sw01_Big_Daddy_16g_GA"
2: fffc02 10:00:00:05:33:4a:c2:a0 10.200.205.151 0.0.0.0 >"fc_sw01_bl_01_PA"
3: fffc03 10:00:00:05:33:6f:1b:66 10.200.205.220 0.0.0.0 "fc_sw01_bl_02_PA"
4: fffc04 10:00:00:27:f8:84:5c:ca 172.17.36.133 0.0.0.0 "fc_sw01_CentralSW8-80_GA"
5: fffc05 10:00:00:27:f8:3c:57:f7 10.200.205.123 0.0.0.0 "fc_sw01_bl_07_PA"
6: fffc06 10:00:00:27:f8:29:07:29 10.200.205.115 0.0.0.0 "fc_sw01_BRSW01_PA"
7: fffc07 10:00:00:27:f8:b5:21:02 172.17.36.161 0.0.0.0 "fc_sw01_bl_02_GA"
8: fffc08 10:00:88:94:71:45:13:b0 172.17.36.223 0.0.0.0 "fc_sw01_huawei_ga"
9: fffc09 10:00:88:94:71:6d:b6:70 172.16.240.20 0.0.0.0 "fc_sw01_wedo_ga"
10: fffc0a 10:00:88:94:71:77:aa:f9 10.200.205.48 0.0.0.0 "fc_sw01_wedo_pa"
11: fffc0b 10:00:88:94:71:44:1e:a8 10.200.205.43 0.0.0.0 "fc_sw01_HUAWEI_PA"
41: fffc29 10:00:00:05:33:c7:ca:eb 172.17.36.82 0.0.0.0 "fc_sw01_bl_03_GA"
44: fffc2c 10:00:00:27:f8:29:11:e1 10.145.151.178 0.0.0.0 "fc_sw01_brocade_TU_GA"
102: fffc66 10:00:00:27:f8:3c:58:00 172.17.36.139 0.0.0.0 "fc_sw01_bl_01_GA"
109: fffc6d 10:00:00:05:33:ab:33:f9 10.200.205.125 0.0.0.0 "fc_sw01_bl_09_PA"
168: fffca8 10:00:00:27:f8:bb:fe:db 10.200.205.168 0.0.0.0 "fc_sw_01_lw16g_PA"
I also noticed that in the frontend in the HW configuration section there are no World Wide Name.
I got the same issue as Micallef. I also have switches in access gateway mode, and even if they are not in fabric per se, I would like to have them in one group with switches they are connected to (fabric).
Now I do have those AG switches in bad group and can't move them to another.
I am using latest v 2.52. -
Hi,we have moved all AG switches to special fabric called "Access Gateway"It is all we can do. They do not belong to any Fabric (means fabric cfg is not shared with them), they also do not report connection to any fabric via SNMP
thank you for the updated version. This is satisfactory solution for me.
Thanks again.
