VMware graph problem
I faced a problem in VMware monitoring. In the Datastore section, when you select a datastore to view the Data and IOPS graph, if you zoom the graph, the Max value would be changed.
I checked this in demo.lpar2rrd.com. For example in Datastore SAN-Comp-production, in DATA graph, the Max for write is 34.59 but when you zoom it, the Max for write becomes 73.88. The Average is not changed.
This problem is also occurred in VMs in DISK graphs. For example vcenter65-new.
I wonder which amount is correct, before or after zooming.
basically standard graphs is not able to fit all data points (1 minutes) therefore it must be averaged.Zooming shows you real maximum.
When operating Liquid XML 2015 on a Windows VM in VMware, the graphical display may not display accurately. This can be determined by turning off graphics acceleration in the VMware layer. This is a common issue when running Microsoft WPF based applications on VMware
for more depth information go through link
https://support.liquid-technologies.com/kb/a112/how-to-fix-graphical-display-issues-with-vmware.aspx
Hi,this forum si dedicated to server&storage perfromance monitporing tools lpar2rrd & stor2rrd.
