IBM Flash System 840 and 900
Hello Pavel,
using Stor2rrd 2.41.
When adding IBM Flash Systems 840 and 900 I see in error.log-flash840 and error.log-flash900:
<snip>
/opt/stor2rrd/bin/svcconfig.pl:566 file:/opt/stor2rrd/data/flash840/svc.config.backup.xml.check
Thu Feb 28 08:55:20 2019 - WARNING - svcconfig.pl: XML parsing error: /opt/stor2rrd/data/flash840/svc.config.backup.xml.check:1: parser error : Input is not proper UTF-8, indicate encoding
Bytes: 0xFF 0x22 0x20 0x2F
perty name="type" value="UNKNOWN(255)" /> <property name="cluster_ip" value="
/opt/stor2rrd/data/flash840/svc.config.backup.xml.check:1: parser error : Input is not proper UTF-8, indicate encoding !
/opt/stor2rrd/data/flash840/svc.config.backup.xml.check:1: element property: output error : invalid character value
Thu Feb 28 08:55:21 2019 - ERROR - svcconfig.pl: XML parsing error: Entity: line 13: parser error : Input is not proper UTF-8, indicate encoding !
Bytes: 0xFF 0x22 0x2F 0x3E
perty name="cluster_ip" value="ÿ"/> <property name="chap_secret" value="
<snip>
Looking into "lssystem" on both Systems I see:
<snip>
tier UNKNOWN(255)
tier_capacity 0.00MB
tier_free_capacity 0.00MB
tier UNKNOWN(255)
tier UNKNOWN(255)
tier UNKNOWN(255)
tier UNKNOWN(255)
<snip>
A change to UTF-8 is not possible as the locale on both Flash Systems do not support this.
Any help would be appreciated.
Cheers,
ku
upgrade to the last version 2.50, this issue should be fixed there. -
Hi,1. definitelly start by upgrading to 2.50, let us know if the issue persist.2. assure you have installed xmllintxmllint -v
Additionally in load.out file I see:<snip>Storage : flash840
Storage type : SWIZ
IO/DATA limits : volume limits : IO_MAX:512; DATA_MAX:2048 RESPONSE_MAX:2 CACHE_MAX:1024
updating RRD : flash840:SWIZ
config file : flash840: no new config input file found
load nicks : flash840 : VOLUME
ERROR : flash840: Can't open /opt/stor2rrd/data/flash840/config.html is missing (fresh install or upgrade?, then wait about 20mins) /opt/stor2rrd/bin/LoadDataModule.pm:35365
ERROR : flash840: Volumes cfg file has not been found : /opt/stor2rrd/data/flash840/VOLUME/volumes.cfg /opt/stor2rrd/bin/storage.pl:13684
ERROR : Exiting flash840 as some core cfg file is missing: config.html || pool.cfg || volumes.cfg
=== Check http://www.stor2rrd.com/install-storage.htm for more ===
<snip>
Thanks for the hints - I'm going to upgrade to 2.50.
Hello Karel, Pavel,upgrade to 2.50 has been successfully done.Both Flash Systems are now recognized by stor2rrd and visible in stor2rrd GUI.So far so good.However I see in Error Log of both Flashsystems:<snip>Thu Feb 28 13:36:52 2019 - ERROR - FlashSystem.pm: SVCPRF201E Upload IOSTAT file current_short//iops failed. - Return code: 101
Thu Feb 28 13:36:52 2019 - ERROR - FlashSystem.pm: SVCPRF201E Upload IOSTAT file current_short//bw failed. - Return code: 101
Thu Feb 28 13:36:52 2019 - ERROR - FlashSystem.pm: SVCPRF201E Upload IOSTAT file current_short//rd_latency_avg failed. - Return code: 101
Thu Feb 28 13:36:52 2019 - ERROR - FlashSystem.pm: SVCPRF201E Upload IOSTAT file current_short//wr_latency_avg failed. - Return code: 101
Use of uninitialized value in concatenation (.) or string at /opt/stor2rrd/bin/FlashSystem.pm line 69.
<snip>Due to this collection of perfdata seems not to work.Am I missing something?Cheers,ku -
Hello Pavel, Karel,is it possible, that ssh_usr (which is IMHO filled by Variable STORAGE_USER in svcperf.pl) is missing in perl Module FlashSystem.pm?We are using a different Username to connect to Flash Storage Systems.<snip>stor2rrd@localhostgrep ssh_usr bin/FlashSystem.pm
my $ssh_usr_ip = shift;
Upload_files($scp,$ssh_usr_ip,$iosdir,$dir1,$dir2,$files);
$cmd_scp .= $ssh_usr_ip.":/".$dir1.$dir2.$file." ";
stor2rrd@localhost /opt/stor2rrd> grep -w ssh_usr bin/FlashSystem.pm
stor2rrd@localhost /opt/stor2rrd>echo $?1<snip>As a workaround I could create the same Username used on my stor2rrd server onto the Flash Storage Systems.Cheers,ku
Workaround does not help.Still seeing in the Error Log of both Flash Systems:<snip>Use of uninitialized value in concatenation (.) or string at /opt/stor2rrd/bin/FlashSystem.pm line 69.
scp: /dumps/tejasstats/current_short//wr_latency_avg: No such file or directory
scp: /dumps/tejasstats/current_short//iops: No such file or directory
scp: /dumps/tejasstats/current_short//rd_latency_avg: No such file or directory
scp: /dumps/tejasstats/current_short//bw: No such file or directory
Thu Feb 28 16:46:41 2019 - ERROR - FlashSystem.pm: SVCPRF201E Upload IOSTAT file current_short//iops failed. - Return code: 101
Thu Feb 28 16:46:41 2019 - ERROR - FlashSystem.pm: SVCPRF201E Upload IOSTAT file current_short//bw failed. - Return code: 101
Thu Feb 28 16:46:41 2019 - ERROR - FlashSystem.pm: SVCPRF201E Upload IOSTAT file current_short//rd_latency_avg failed. - Return code: 101
Thu Feb 28 16:46:41 2019 - ERROR - FlashSystem.pm: SVCPRF201E Upload IOSTAT file current_short//wr_latency_avg failed. - Return code: 101
Thu Feb 28 16:46:42 2019 - ERROR - FlashSystem.pm: SVCPRF201E Upload IOSTAT file current_short//iops failed. - Return code: 101
Thu Feb 28 16:46:42 2019 - ERROR - FlashSystem.pm: SVCPRF201E Upload IOSTAT file current_short//bw failed. - Return code: 101
Thu Feb 28 16:46:42 2019 - ERROR - FlashSystem.pm: SVCPRF201E Upload IOSTAT file current_short//rd_latency_avg failed. - Return code: 101
Thu Feb 28 16:46:42 2019 - ERROR - FlashSystem.pm: SVCPRF201E Upload IOSTAT file current_short//wr_latency_avg failed. - Return code: 101
<snip>Cheers,ku
Hi,send us this output:1. ssh stor2rrd@<flash> "lsportfc -delim ,"2. and this file:tar cvf xml.tar data/SVCPRF201E/*xml*gzip -9 xml.tar
Hello Pavel,output of lsportfc sent.XML File not found:stor2rrd@kerp-nim002 /opt/stor2rrd> tar cvf xml.tar data/SVCPRF201E/*xml*
tar: can't change directories to data/SVCPRF201E: No such file or directoryOr do you meant to havetar cvf xml.tar data/<NAME_OF_FLASHARRAY>/*xml*?Cheers,ku
Those last mentioned XML Files do exist:<snip>stor2rrd@kerp-nim002 /opt/stor2rrd> ls -al data/<NAME_OF_FLASHARRAY>/*xml*-rw-r--r-- 1 stor2rrd staff 203627 Mar 4 02:00 data/<NAME_OF_FLASHARRAY840>/svc.config.backup.xml.check
-rw-r--r-x 1 stor2rrd staff 208116 Mar 4 02:00 data/<NAME_OF_FLASHARRAY840>/svc.config.cron.xml_1321362-1
-rw-r--r-- 1 stor2rrd staff 197717 Mar 4 02:00 data/<NAME_OF_FLASHARRAY900>/svc.config.backup.xml.check
-rw-r--r-x 1 stor2rrd staff 196927 Dec 1 2017 data/<NAME_OF_FLASHARRAY900>/svc.config.cron.xml_6865976-1
-rw-r--r-x 1 stor2rrd staff 202089 Mar 4 02:00 data/<NAME_OF_FLASHARRAY900>/svc.config.cron.xml_6865976-2<snip>In case you need them give me notice.Cheers,ku
Hi,yes, send us this:data/<NAME_OF_FLASHARRAY900>/svc.config.cron.xml_6865976-2and outpu from: ssh stor2rrd@<flash> "lsportfc -delim ,"
Files have been uploaded.lsportfc has been uploaded before.
Hi,this data yet pls (3 files):cd /home/stor2rrd/stor2rrdtar cvf log3.tar tmp/<NAME_OF_FLASHARRAY900>*txtgunzip -9 ...
File uploaded.
Files requested via Mail uploaded.
Solved.Downloaded Fix for 2 Perl Scripts/Modules from Pavel.Todo:rm -f stor2rrd_base_dir/data/<name_of_storage>/*xml*rm -f stor2rrd_base_dir/data/<name_of_storage>/*data*rm -f stor2rrd_base_dir/data/<name_of_storage>/*data*Fixes:http://www.stor2rrd.com/download/FlashSystem.pm.gz
-rwxr-xr-x 1 stor2rrd stor2rrd 29705 Mar 11 07:23
mv FlashSystem.pm.gz FlashSystem.pm
http://www.stor2rrd.com/download/svcconfig.pl.gz
-rwxr-xr-x 1 stor2rrd stor2rrd 102309 Mar 11 07:23mv svcconfig.pl stor2rrd_base_dir/bin/svcconfig.pl
Wait an hour, then data should be there.Thanks to Pavel for looking into this.Cheers,ku
Typo:lastrm -f stor2rrd_base_dir/data/<name_of_storage>/*data*should be change to:rm -f stor2rrd_base_dir/data/<name_of_storage>/*out*
