Problem with pdf export for Historical reports
In LPAR2RRD, VMware section, when I tried to get PDF export from Historical reports of a vCenter for VMs, the dialogue box was opened and started to count from 1of 9 to 9 of 9 and then it stopped. Nothing was happened even after pressing Cancel button. The point is no matter how many VMs I like to get report from, the PDF export always counts to 9.
PDF exporting for the other items (Clusters, Resource pool and Datastores) works fine.
Hi,does that fail even if you choose other 9 VMs?What happen if you select less VMs than 9?
Even when I chose 1 VM, it did the same. I tried with more than 9 VMs also, but still it was shown 9.
ok, I see it, we are able to simulate it. We will send you a fix soon.Anyway free version has a limitation to 1 VM in single pdf
OK, thanks.
http://www.lpar2rrd.com/download-static/vcenter-list-cgi.pl.gzGunzip it and copy to /home/lpar2rrd/lpar2rrd/bin (755, lpar2rrd owner)
If your web browser gunzips it automatically then just rename it: mv vcenter-list-cgi.pl.gz vcenter-list-cgi.pl
Assure that file size is same as above listed one
-rwxrwxr-x 1 lpar2rrd lpar2rrd 31039 Nov 28 15:02 vcenter-list-cgi.pl
It works. Thank you very much.
