Problem with Reporter in v2.40
Hi,do you have data in the graph for same time range when you check that storage via GUI?
Yes, the graphs generated normally by GUI contains data, but the graphs generated by Reporter at the same time are empty.
Hi,pls this logs:
cd /home/stor2rrd/stor2rrd # or where is your STOR2RRD working dir tar cvhf logs.tar logs etc tmp/*txt reports/*log gzip -9 logs.tar Send us logs.tar.gz via https://upload.stor2rrd.com
Attach also screenshot from reporter and GUI.
I uploaded the log files. The requested screenshots are attached
they are different reports1. it is last ended month (September)2. it is last 31 daysYou can see that data is there only since 9th of Oct.The first report time range does not cover it.
OK. Thank you very much.
