Correct SNMP setting for FC5022
Hi all.
Brocade FC5022:
Brocade FC5022:
FC5022:user> snmpconfig --show snmpv3SNMP Informs = 0 (OFF)SNMPV3 user password encrypted = 0 (OFF)SNMPv3 USM configuration:User 1 (rw): mmv3_mgrAuth Protocol: SHAPriv Protocol: AES128User 2 (rw): snmpadmin2Auth Protocol: SHAPriv Protocol: DESUser 3 (rw): snmpadmin3Auth Protocol: SHAPriv Protocol: DESUser 4 (ro): snmpuser1Auth Protocol: noAuthPriv Protocol: noPrivUser 5 (ro): snmpuser2Auth Protocol: SHAPriv Protocol: DESUser 6 (ro): prtgAuth Protocol: SHAPriv Protocol: AES128User 7 (ro): iomAuth Protocol: SHAPriv Protocol: DESSNMPv3 Trap/Informs configuration:Trap Entry 1: FE80::0211:25FF:FEC3:ECA0Trap Port: 162Trap User: mmv3_mgrTrap recipient Severity level: 0Notify Type: TRAP(1)Trap Entry 2: No trap recipient configured yetNotify Type: TRAP(1)Trap Entry 3: No trap recipient configured yetNotify Type: TRAP(1)Trap Entry 4: No trap recipient configured yetNotify Type: TRAP(1)Trap Entry 5: No trap recipient configured yetNotify Type: TRAP(1)Trap Entry 6: prtg.localTrap Port: 162Trap User: prtgTrap recipient Severity level: 4Notify Type: TRAP(1)Trap Entry 7: No trap recipient configured yetNotify Type: TRAP(1)
FC5022:user> snmpconfig --show accessControlSNMP access list configuration:Entry 0: No access host configured yetEntry 1: No access host configured yetEntry 2: No access host configured yetEntry 3: No access host configured yetEntry 4: No access host configured yetEntry 5: No access host configured yet
FC5022:user> firmwareshowFrom stor2rrd:
Appl Primary/Secondary Versions
FOS v8.2.0
v8.2.0
[lpar2rrd@stor2rdd ~]$ snmpwalk -v 3 -u snmpuser1 SwitchIp 1.3.6.1.2.1.1.5
snmpwalk: Unknown user name
I checked this forum https://forum.xorux.com/discussion/471/fc5022-san-switch-issue-unsupported-security-level. The settings look correct. Can anyone check in their environment?
Any suggestions?
what returns this command?brocade01:admin> snmpconfig --show secLevel
GET security level = 0, SET level = 0
SNMP GET Security Level: No security
SNMP SET Security Level: No security
Hi.
FC5022:admin> snmpconfig --show secLevel
GET security level = 0, SET level = 3
SNMP SET Security Level: No Access -
snmpv1 works?snmpwalk -v 1 -c <community string> <SwitchIp> 1.3.6.1.2.1.1.5
Yes, if I previously enable it:
snmpconfig --enable snmpv1 Committing configuration.....done.
Then:[lpar2rrd@stor2rdd bin]$ snmpwalk -v 1 -c public SwitchIP 1.3.6.1.2.1.1.5 SNMPv2-MIB::sysName.0 = STRING: FC5022
as per manual, do not you use snmp host access list?if so, is stor2rrd host allowed?
do you have more switches?Are they working fine?
Hi, Pavel.
I have two switches in the chassis. Both work normally. But snmp3 does not work with stor2rrd. Other monitoring systems work fine with snmp3.
The access list is empty on both:snmpconfig --show accessControl SNMP access list configuration: Entry 0: No access host configured yet Entry 1: No access host configured yet Entry 2: No access host configured yet Entry 3: No access host configured yet Entry 4: No access host configured yet Entry 5: No access host configured yet
what is difference between working and not working switches?FOS? other HW?I am afraid we cannot help you more, we have tried everything we know.Try Brocade support.
Pavel, thanks for the help.
As a workaround, I enabled the snmpv1 protocol.
