vmware connect.pl issue
Hi
My LPAR2RRD version 5.07
I installed VMware-vSphere-Perl-SDK-6.5.0
My LPAR2RRD is on the Ubuntu 16.04
vSphere SDK for Perl version: 6.5.0
Script 'connect.pl' version: 1.0
vSphere Client Version 5.1.0
VMware ESXi Version 5.1.0
When i tested on the CLİ ,i saw this error
$PERL /home/lpar2rrd/lpar2rrd/vmware-lib/apps/connect.pl --server x.x.x.x --username "lpar2rrd@y.y.y.y" --password "****"
Server version unavailable at 'https://x.x.x.x:443/sdk/vimService.wsdl' at /home/lpar2rrd/lpar2rrd/vmware-lib/apps/../VMware/VICommon.pm line 734.
Could you help please?
When i tested on the LPAR2RRD gui,i saw this error;
Looks like there is no running vCenter or ESXi on: https://x.x.x.x
1. assure that your user is created properly, has read only rights for whole vcenter:
http://www.lpar2rrd.com/install.htm?4.1.0 --> VMware --> screenshot in pre-requisite section
2. when above ok, then this test to prove that there is network connection to your vcenter, replace vcenter_IP by your IP or hostname
cd /home/lpar2rrd/lpar2rrd
perl ./bin/conntest.pl vcenter_IP 443
Hi
I checked this.
This my CLİ screen:
lpar2rrd@lpartest:~$
lpar2rrd@lpartest:~$ cd /home/lpar2rrd/lpar2rrd
lpar2rrd@lpartest:~/lpar2rrd$ perl ./bin/conntest.pl x.x.x.x 443
Greetings
I still saw same error too
screenshot pls:
telnet IP 443
Hi
this is the my CLI
telnet x.x.x.x 443
lpar2rrd@lpartest:~/lpar2rrd$ telnet x.x.x.x 443
Trying x.x.x.x...
Connected to x.x.x.x.
Escape character is '^]'.
Greetings
Hi
I checked on my system perl -MLWP -le "print(LWP->VERSION)" with this command
lpar2rrd@lpartest:~$ perl -MLWP -le "print(LWP->VERSION)"
6.15
My system version is:
Distributor ID: Ubuntu
Description: Ubuntu 16.04.2 LTS
Release: 16.04
Codename: xenial
Hi
lpar2rrd@lpartest:~$ perl -MLWP -e 'print "LWP Version: $LWP::VERSION\n"'
LWP Version: 6.15
Greetings
