Web page is not working after stor2rrd agent installation
We have installed the stor2rrd-2.10 agent on RHEL 6.9 node where already lpar2rrd agent installed. But we are not able to access through GUI as http://10.240.87.154/stor2rrd and we are getting an error as
You don't have permission to access /stor2rrd/ on this server.
Apache/2.2.15 (Red Hat) Server at 10.240.87.154 Port 80
Srini
Srini
looks like Apache cfg issue.
configure Apache httpd.conf as per docu (similary like is lpar2rd cfg), do not forget to restart apache:
apachectl restart
We have already updated in httpd.conf and restarted the httpd services and still getting same error.AddHandler cgi-script .sh# DocumentRoot "/usr/local/capinfo/stor2rrd/stor2rrd/www/"Alias /stor2rrd "/usr/local/capinfo/stor2rrd/stor2rrd/www/"<Directory "/usr/local/capinfo/stor2rrd/stor2rrd/www/">AllowOverride AuthConfigOptions Indexes FollowSymLinks Includes MultiViewsRequire all granted</Directory># CGI-BINScriptAlias /stor2rrd-cgi/ "/usr/local/capinfo/stor2rrd/stor2rrd/stor2rrd-cgi/"<Directory "/usr/local/capinfo/stor2rrd/stor2rrd/stor2rrd-cgi">AllowOverride AuthConfigSetHandler cgi-scriptOptions ExecCGI Includes FollowSymLinksRequire all granted</Directory></VirtualHost># pwd/etc/httpd/conf[root@ hdxxxxconf]#[root@ hdxxxxconf]# service httpd restartStopping httpd: [ OK ]Starting httpd: httpd: Could not reliably determine the server's fully qualified domain name, using 10.240.87.154 for ServerName[ OK ][root@ hdxxxxconf]#
Forbidden
Apache/2.2.15 (Red Hat) Server at 10.240.87.154 Port 80 -
check Apache error_log, there must be visible this issue
It is somewhere in /var usually
find /var -name error_log
[root@HDLPCLST01 var]# cat /var/log/httpd/error_log[Sun Feb 25 03:28:05 2018] [notice] Digest: generating secret for digest authentication ...[Sun Feb 25 03:28:05 2018] [notice] Digest: done[Sun Feb 25 03:28:05 2018] [notice] Apache/2.2.15 (Unix) DAV/2 configured -- resuming normal operations[Sun Feb 25 20:30:29 2018] [notice] caught SIGTERM, shutting down[Sun Feb 25 20:30:30 2018] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)[Sun Feb 25 20:30:30 2018] [notice] Digest: generating secret for digest authentication ...[Sun Feb 25 20:30:30 2018] [notice] Digest: done[Sun Feb 25 20:30:30 2018] [notice] Apache/2.2.15 (Unix) DAV/2 configured -- resuming normal operations[Mon Feb 26 10:17:53 2018] [notice] caught SIGTERM, shutting down[Mon Feb 26 10:17:53 2018] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)[Mon Feb 26 10:17:53 2018] [notice] Digest: generating secret for digest authentication ...[Mon Feb 26 10:17:53 2018] [notice] Digest: done[Mon Feb 26 10:17:53 2018] [notice] Apache/2.2.15 (Unix) DAV/2 configured -- resuming normal operations[Mon Feb 26 10:26:03 2018] [notice] SIGHUP received. Attempting to restarthttpd: Could not reliably determine the server's fully qualified domain name, using 10.240.87.154 for ServerName[Mon Feb 26 10:26:03 2018] [notice] Digest: generating secret for digest authentication ...[Mon Feb 26 10:26:03 2018] [notice] Digest: done[Mon Feb 26 10:26:03 2018] [notice] Apache/2.2.15 (Unix) DAV/2 configured -- resuming normal operations[root@HDLPCLST01 var]#
tail /var/log/httpd/access_log
Hi having the same issue, how did it finally get fix ?
