Custom Group problem
I tried to build some custom groups but no matter how much systems or lpars are shown in the preview in the group-view are only shown up to four entries:
another example with Pool-type custom group
A second thing I don't understand is why in the example above the CPU cores on both machines shown are listed and counted twice: Once in Pool "CPU pool" and once in pool "default pool" even though the machine only has 8 in total. Is this a bug or am I using the custom groups wrong?
Thanks in advance for any help!
regards,
Stephan
1. there should not be any restriction on selecting items for custom groups (perhaps no more than 4 lpar matches), however there is a restriction further in for number of presented lpars in graphs (limit is 4 in free version)
Read this: http://www.lpar2rrd.com/support.htm?3.0#benefits
2. ok, this is wrong, default pool should not be there.
As workaround use "CPU pool" string in configuration field as a pool name.
We will fix it in next version.
