No capacity and perf data captured for DataDomain (DD860)
in EMC
Hello Stor2rrd Team,
After discovering the DD860 in Stor2rrd, I can see only configuration and Health status of DD. Capacity and Perf data are not captured even after a week time.
DD860 OS version is 5.4 and Stor2rrd version is 2.20
Below are the errors in log file and same are repeating every 5 mins.
**** Invalid argument: "ddboost". Valid strings are: nfs, cifs, repl, net, iostat, sysstat.
Sat Feb 10 16:10:05 2018: command failed: system show stats view nfs cifs repl ddboost net interval 150 count 3 /storage/stor2rrd/bin/datadomainperf.pl:3586 :
Sat Feb 10 16:10:11 2018: command failed: mtree show performance /data/col1/Tesco1 last 1hours /storage/stor2rrd/bin/datadomainperf.pl:3611 :
Sat Feb 10 16:10:12 2018: command failed: mtree show performance /data/col1/aftd last 1hours /storage/stor2rrd/bin/datadomainperf.pl:3611 :
Sat Feb 10 16:10:12 2018: command failed: mtree show performance /data/col1/backup last 1hours /storage/stor2rrd/bin/datadomainperf.pl:3611 :
Sat Feb 10 16:10:13 2018: command failed: mtree show performance /data/col1/myppnwkrho01 last 1hours /storage/stor2rrd/bin/datadomainperf.pl:3611 :
**** Invalid number: "custom-view".
Sat Feb 10 16:10:14 2018: command failed: system show performance custom-view throughput protocol cache-miss latency compression utilization duration 10 min interval 5
min /storage/stor2rrd/bin/datadomainperf.pl:3611 :
Sat Feb 10 16:10:22 2018: File not exist /storage/stor2rrd/data/MYPPNWKRHO03/IOSTATS/05/perf_stat.txt: No such file or directory/storage/stor2rrd/bin/datadomainperf.pl:
3661 : No such file or directory
Use of uninitialized value $timestamp in subtraction (-) at /storage/stor2rrd/bin/datadomainperf.pl line 2626.
Use of uninitialized value $timestamp_end in localtime at /storage/stor2rrd/bin/datadomainperf.pl line 3750.
Use of uninitialized value $timestamp_end in localtime at /storage/stor2rrd/bin/datadomainperf.pl line 3751.
Sat Feb 10 16:10:22 2018: File not exist /storage/stor2rrd/data/MYPPNWKRHO03/IOSTATS/05/system_stat.txt: /storage/stor2rrd/bin/datadomainperf.pl:3661 :
Use of uninitialized value $timestamp in subtraction (-) at /storage/stor2rrd/bin/datadomainperf.pl line 612.
Use of uninitialized value $timestamp in subtraction (-) at /storage/stor2rrd/bin/datadomainperf.pl line 241.
Use of uninitialized value $timestamp in subtraction (-) at /storage/stor2rrd/bin/datadomainperf.pl line 453.
Send us logs pls.
ps -ef |egrep "2rrd" > tmp/ps_log.txt
tar cvhf logs.tar logs etc tmp/*txt data/MYPPNWKRHO03/IOSTATS/*
You might even attach screenshots when it helps in understanding of the issue.
Hello Lukas,
Uploaded the logs. Can you review them?
Thanks -
you have older firmware version 5.4 which does not recognize some command parameters we expect (we actually support 5.5+)
We will fix that during next week.
Has this been solved? I'm running into the same issue with the same DD OS rel
STOR2RRD v2.31-1
Hi,unfortunatelly appeared that v5.4 is quite different and implementation effort would be very high.We have gave it up, it is not priority for us. Supported are 5.5+
- 116 XorMon
- 140 STOR2RRD
