SAN switch which have same name ( not on same fabric )
Hi Everyone
I have install and config stor2rrd for monitor Storage and SAN . Storage I no have any problem . But for SAN I have problem about collect data because some SAN switch have same name then when I looking in web I will see only 1 switch . If I need to use IP instead switch name , possible ? If answer is yes . Please give me for instruction .
you mean that you have same name of switech accross your fabrics?
Yes
it will not work, the tool expects unique switch names
There is no simple fix from our side, question is if using same switch names is a good practise
I agree with you about same switch name is not good practice . Then I will convince my client to change switch name . Thank you very much.
