Missing SAN data from agent running on RHEL5 with QLogic HBAs
REDHAT 5 does not populate tx_words or rx_words, so the collection for the san data is does not work.
[root@...... /]# cat /sys/class/fc_host/host1/statistics/tx_words
0xffffffffffffffff
https://bugzilla.redhat.com/show_bug.cgi?id=642424 (Mentions RHEL6 but..)
I've created a workaround to define it as 1, which allows me to get tx_frames / rx_frames.
--- lpar2rrd-agent.pl 2017-10-19 14:24:39.000000000 +0100
+++ lpar2rrd-agent.pl.orig 2017-10-19 14:25:08.000000000 +0100
my $data = <FH>;
chomp($data);
close(FH);
- $data = 1 if ($data eq '0xffffffffffffffff');
if ( ishexa($data) == 1 ) {
$tx_words = sprintf( "%d", hex($data) ) * 4; # convert to Bytes
my $data = <FH>;
chomp($data);
close(FH);
$rx_words = sprintf( "%d", hex($data) ) * 4; # convert to Bytes
Clunky, but so far seems OK
I only get IOPS and not throughput but better than nothing.
Thanks,
0xffffffffffffffff
my $data = <FH>;
chomp($data);
close(FH);
my $data = <FH>;
chomp($data);
close(FH);
Thanks,
thanks!
What about to try this code instead?
if ( ! $data eq '0xffffffffffffffff' && ishexa($data) == 1 ) {
with your change there will be alway presented traffic 4, this should skip it what is more correct. There should be no data == NaNQ
Can you test it? It should work as that if it is correctly coded on the daemon side.
Thanks - will update that, I didnt check the daemon code - wasnt sure if it would graph with partial data
let me know when it works, I am also not sure
The above fix breaks it
I think because $tx_words is empty which then fails the test below (line 2067ish)
if ( !$tx_frames eq '' && !$rx_frames eq '' && !$tx_words eq '' && !$rx_words eq '' ) {
what means brakes it, data is not imported at all, right?
Yeah, not recorded/not sent so not imported
sorry, did not read it via the web, just the first line in email notification I noted.
Yes, it is obvious of course.
