No Data in shown in for SAN Switches in stor2rrd
I have configured stor2rrd with SAN switches, in left hand side I can see the list of SAN switches configured but there is no data generated for graph.
I tested the below command, its working correctly.
Avi
snmpwalk -v 1 -c public <Switch_IP> 1.3.6.1.2.1.1.5 SNMPv2-MIB::sysName.0 = STRING: SAN_switch_name I noticed that under Stor2rrd > SAN switches > Configuration tab > Port state > Is shown as Unused. Will it still show the data if port state is shown as unused ? Can you please let us know if stor2rrd SAN configuration I have done is correct and if any additional configuration is needed from stor2rrd or SAN switches side.Thanks,
Avi
run this to verify configuration:
su - stor2rrd
cd /home/stor2rrd/stor2rrd
./bin/config_check.sh
It all is ok then you should see data in the GUI.
Hi Pavel, Thanks for response. I tried the config_check.sh, I got the result as
SAN: <IP Address> : OK. Is there any configuration I am missing on SAN side for permission ? -
Send us logs pls. Note a short problem description in the text field of the upload form.
find data -exec ls -ld {} \; > tmp/list_data.txt
ps -ef |egrep "2rrd" >> tmp/list_data.txt
tar cvhf logs.tar logs etc tmp/*txt *out
I've got the same problem with aviratna.
I've already follow the instruction to get the logs.tar.gz.
Can i upload it? So you can analyze.
Thanks,
Jony
yes, send us logs.
Sorry pavel my mistake. The data already show now. I think there was no traffic so the data didn't shows up.
Thanks Pavel.
Jony
- 116 XorMon
- 140 STOR2RRD
