custom port for clients
yes
lpar2rrd-agent.pl [-d] [-c] [-n __NMON_DIR__] __LPAR2RRD-SERVER__[:__PORT__] -
OK, as I expected, thanks
I dont want to open new topic, but I just dont see data from client on WEB page. Data are probably received:
grep bla /home/lpar2r_2/lpar2rrd/load.out
add to menu L : no_hmc:Linux--unknown:bla.bla.com : lpar_url:bla.bla.com : OS agent
The client was configured about 3 hours ago -
You mean that you do not see data or the client entry at all? I suppose the entry.
you should see it in the GUI if it is printed here:
grep bla /home/lpar2r_2/lpar2rrd/tmp/menu.txt
If not then Ctrl-F5 in the GUI or try another browser to exclude browser caching.
I meant "no entry".
there is a corresponding line in menu.txt: "...host=no_hmc&server=Linux--unknown&lpar=....", I presume I shoud see "+no_hmc" item as "first level" submenu? -
I also tried different browser
Hi Tibor,
please send us your menu.txt file via https://upload.lpar2rrd.com , we'll check it -
You should see it under "Linux" item in SERVER level.
I just sent you a screenshot
I see it. There is no IBM Power server, just VMware. This might cause a problem. We will look at it and let you know soon.
Yes, we have two instances of LPAR2RRD, this one is just VMware + linux servers, some of them standalone
