Configuration Problem
i am using the virtual appliance ver. 1.35 with the following san-list.cfg:
SNMP_VERSION=3
192.168.249.58:snmppass1:BRCD:Fabric_1
192.168.249.59:snmppass1:BRCD:Fabric_2
192.168.249.78:snmppass1:BRCD:
192.168.249.79:snmppass1:BRCD:
192.168.249.175:snmppass1:BRCD:
192.168.249.176:snmppass1:BRCD:
192.168.249.58:snmppass2:BRCD:
192.168.249.59:snmppass2:BRCD:
192.168.249.175:snmppass2:BRCD:
192.168.249.176:snmppass2:BRCD:
Result from config_check.sh:
SWITCH: 192.168.249.58
Type : BRCD
DestHost : 192.168.249.58
Version SNMP : 3
SecName : snmppass1
SNMP port : not defined! Used SNMP default port "161"!
Switch name : RZ1-SANPRIVF1
STATE : CONNECTED!
SWITCH: 192.168.249.59
Type : BRCD
DestHost : 192.168.249.59
Version SNMP : 3
SecName : snmppass1
Switch name : RZ1-SANPRIVF2
STATE : CONNECTED!
SWITCH: 192.168.249.78
Type : BRCD
DestHost : 192.168.249.78
Version SNMP : 3
SecName : snmppass1
Switch name : RZ3-SANSWF1
STATE : CONNECTED!
SWITCH: 192.168.249.79
Type : BRCD
DestHost : 192.168.249.79
Version SNMP : 3
SecName : snmppass1
Switch name : RZ3-SANSWF2
STATE : CONNECTED!
SWITCH: 192.168.249.175
Type : BRCD
DestHost : 192.168.249.175
Version SNMP : 3
SecName : snmppass1
Switch name : RZ4-SANPRIVF1
STATE : CONNECTED!
SWITCH: 192.168.249.176
Type : BRCD
DestHost : 192.168.249.176
Version SNMP : 3
SecName : snmppass1
Switch name : RZ4-SANPRIVF2
STATE : CONNECTED!
Type : BRCD
Version SNMP : 3
SecName : snmppass1
STATE : CONNECTED!
Type : BRCD
Version SNMP : 3
SecName : snmppass1
STATE : CONNECTED!
Type : BRCD
Version SNMP : 3
SecName : snmppass1
STATE : CONNECTED!
Type : BRCD
Version SNMP : 3
SecName : snmppass1
STATE : CONNECTED!
Stor2rrd uses always "snmppass1". If i change the order in san-list.cfg (first snmppass2 appears), stor2rrd uses always snmppass2.
SNMP is working correctly.
Thanks, Michael
SNMP_VERSION=3
Type : BRCD
Version SNMP : 3
SecName : snmppass1
STATE : CONNECTED!
Type : BRCD
Version SNMP : 3
SecName : snmppass1
STATE : CONNECTED!
Type : BRCD
Version SNMP : 3
SecName : snmppass1
STATE : CONNECTED!
Type : BRCD
Version SNMP : 3
SecName : snmppass1
STATE : CONNECTED!
Type : BRCD
Version SNMP : 3
SecName : snmppass1
STATE : CONNECTED!
Type : BRCD
Version SNMP : 3
SecName : snmppass1
STATE : CONNECTED!
Type : BRCD
Version SNMP : 3
SecName : snmppass1
STATE : CONNECTED!
Type : BRCD
Version SNMP : 3
SecName : snmppass1
STATE : CONNECTED!
Type : BRCD
Version SNMP : 3
SecName : snmppass1
STATE : CONNECTED!
Type : BRCD
Version SNMP : 3
SecName : snmppass1
STATE : CONNECTED!
Thanks, Michael
Workaround: use FQDN instead of IP for the second SecName. Works only for 2 VF on Switch
you have to use only one SecName (security user) for all Virtual Fabrics.
Try this configuration:
http://www.stor2rrd.com/install.htm -> SAN tabBrocade Virtual Fabric support
- Configure security user on the switch (under admin account):Parameter -l says which virtual fabrics can be monitored by this user.
userconfig --add snmpuser1 -r user -l 1,128 userconfig --change snmpuser1 -r user -l 1,128 -h 128 -e no
Example above allows virtual fabrics 1 and 128 for user snmpuser1.
Thanks a lot.
