errors in script /home/stor2rrd/stor2rrd/load.sh
when our script runs ( hourly ) we get the message:
( removed lines before )
start time stor: Fri Jan 6 10:33:56 CET 2017
STOR2RRD free version 1.35-1 (1.35-1)
Host : pmg-bob01.onprvp.fgov.be
Alarm : 3600
RRDTool version: 1.3008
Storage : XIV7803191
Storage type : XIV
IO/DATA limits : volume limits : IO_MAX:50; DATA_MAX:2048 RESPONSE_MAX:8 CACHE_MAX:2048
updating RRD : XIV7803191:XIV
config file : XIV7803191: no new config input file found
load nicks : XIV7803191 : VOLUME
loaded nicks : XIV7803191 82 (volume: 82)
volume cfg changed: 1
creating cfg : not this time - same day
clean old tmp : not this time - same day
creating cmd : XIV7803191:POOL:sum_io:d
creating cmd : XIV7803191:POOL:sum_data:d
creating cmd : XIV7803191:POOL:read_io:d
creating cmd : XIV7803191:POOL:read:d
creating cmd : XIV7803191:POOL:resp_t_r:d
creating cmd : XIV7803191:POOL:write_io:d
creating cmd : XIV7803191:POOL:write:d
creating cmd : XIV7803191:POOL:resp_t_w:d
creating top : XIV7803191:VOLUME:top:d
ERROR : volumes stats: /home/stor2rrd/stor2rrd/data/XIV7803191/VOLUME/1076978.rrd does not exist, continuing /home/stor2rrd/stor2rrd/bin/storage.pl:7473
creating cmd : XIV7803191:VOLUME:read_io:d
creating cmd : XIV7803191:VOLUME:read:d
creating cmd : XIV7803191:VOLUME:resp_t_r:d
creating cmd : XIV7803191:VOLUME:write_io:d
creating cmd : XIV7803191:VOLUME:write:d
creating cmd : XIV7803191:VOLUME:resp_t_w:d
global vol top : XIV7803191:VOLUME:top:avrg:d
global vol top : XIV7803191:VOLUME:top:avrg:w
global vol top : XIV7803191:VOLUME:top:avrg:m
global vol top : XIV7803191:VOLUME:top:max:d
global vol top : XIV7803191:VOLUME:top:max:w
global vol top : XIV7803191:VOLUME:top:max:m
Custom start : free : 1
Finished : Fri Jan 6 10:34:10 2017, run time: 0 secs
in the error ; the script wants
but we have this:
This is not a real volume on XIV but a reference for ofline replication of a volume, maybe this is the problem?
QUESTION:
1) how to clean?
2) can we exclude these type of volumes?
Greetings,
but we have this:
[root@pmg-bob01 ~]# ll /home/stor2rrd/stor2rrd/data/XIV7803191/VOLUME/1076978*.rrd
-rw-r--r-- 1 stor2rrd stor2rrd 2120528 Jan 6 11:15 /home/stor2rrd/stor2rrd/data/XIV7803191/VOLUME/1076978-P393089.rrd
[root@pmg-bob01 ~]# grep 1076978 /home/stor2rrd/stor2rrd/data/XIV7803191/VOLUME/volumes.cfg
last-replicated-vmware_onp_PEGASOS_lpr-bat01_SRM_vgpegasosprod : 1076978;
QUESTION:
1) how to clean?
Greetings,
only VolumesTOP is affected. Can you see there any volume from this storage?
Pls once more this, strange above error should not happen:
ls -l /home/stor2rrd/stor2rrd/data/XIV7803191/VOLUME/1076978*
To Pavel,
not only in the "TOP" ,
But also here into the "yearly" screen AND the "aggregated" view
PS: this devices are no read devices , but references used in XIV to dynamicly sync a pool from one XIV to an other. -
Send us logs pls. Note a short problem description in the text field of the upload form.
find data -exec ls -ld {} \; > tmp/list_data.txt
ps -ef |egrep "2rrd|svc|xiv|ds8|ds5|hus|vspg|netapp|horcm" >> tmp/list_data.txt
tar cvhf logs.tar logs etc tmp/*txt *out # do not miss "h" option in tar
