Brocade SAN Switch 300, configure, load but not appear in http:///stor2rrd
Hi
I have configure in san-list.cfg in the virtual appliance for version 1.35 free
config_check.sh
I run load.sh in/home/stor2rrd/stor2rrd and get the following files inside /home/stor2rrd/stor2rrd/data/penbrfc1
I have configure the necessary according to the installation steps in http://www.stor2rrd.com/install.htm?1.2
However I don't see any SAN switch name 'penbrfc1' at the left pane of the hierarchy tree?
Anything that is missing?
Thanks.
SNMP_VERSION=3
157.165.162.77:snmpuser3:BRCD:Penbrfc1
SNMP_PORT=161
config_check.sh
SWITCH: 157.165.162.77
Type : BRCD
DestHost : 157.165.162.77
Version SNMP : 3
SecName : snmpuser3
Community : snmpuser3
SNMP port : 161
Switch name : penbrfc1
STATE : CONNECTED!
config.cfg port11.first port14.rrd port18.first port20.rrd port24.first port4.rrd port8.first
fabric.txt port11.rrd port15.first port18.rrd port21.first port24.rrd port5.first port8.rrd
penbrfc1_sanperf_20161201_1456.out.tmp port12.first port15.rrd port19.first port21.rrd port2.first port5.rrd port9.first
penbrfc1_sanperf_20161201_1457.out.tmp port12.rrd port16.first port19.rrd port22.first port2.rrd port6.first port9.rrd
PHYS_PORTS.cfg port13.first port16.rrd port1.first port22.rrd port3.first port6.rrd PORTS.cfg
port10.first port13.rrd port17.first port1.rrd port23.first port3.rrd port7.first SAN-BRCD
port10.rrd port14.first port17.rrd port20.first port23.rrd port4.first port7.rrd total_summary.rrs
Thanks.
I have the exact same problem. I'm missing the SAN button in the left pane after everything is working now.
ok, I see the problem, SAN switche is not in menu, pls this output:
cd /home/stor2rrd/stor2rrd
date
ls -l tmp/menu.txt
grep SAN tmp/menu.txt| wc -l
If tmp/menu.txt timestamp is not from today then
./load.sh html
Ctrl-F5 in the GUI once it finishes
when nothing then logs pls:
find data -exec ls -ld {} \; > tmp/list_data.txt
tar cvhf logs.tar logs etc tmp/*txt tmp/*out # do not miss "h" option in tar
Thank you Pavel, that solved my problem.
Pls more details. Have you just added the 1st switch into stor2rrd?
Then it will appear in the GUI after next schedulled load.sh from crontab and refresh of the web browser.
2 issue could be
- not running load.sh after switch addition
- not refreshed browser
can you confirm that it could be your case just to be sure that it works as expected.
Yes, I first added 1 switch to the san-list.cfg file. After that I checked it with config_check.sh to be sure that the switch can be connected. Then I run the load.sh.
After that I added the additional 3 switches, run config_check.sh and load.sh again but no "SAN SWITCH" entry showed up in the left pane.
Now I have the problem, that the graph of the 1st switch is empty and the other ones having error messages. I assume it is because of this error while running load.sh:Thu Dec 1 16:21:08 2016: Could not find port1 file: /home/lpar2rrd/stor2rrd/data/SW-RZ2-703/port1.rrd ./bin/san.pl:1608Thu Dec 1 16:21:08 2016: Could not find port2 file: /home/lpar2rrd/stor2rrd/data/SW-RZ2-703/port2.rrd ./bin/san.pl:1608Thu Dec 1 16:21:08 2016: Could not find port3 file: /home/lpar2rrd/stor2rrd/data/SW-RZ2-703/port3.rrd ./bin/san.pl:1608Thu Dec 1 16:21:08 2016: Could not find port4 file: /home/lpar2rrd/stor2rrd/data/SW-RZ2-703/port4.rrd ./bin/san.pl:1608
But I think it is better to open a new thread for this issue? -
Correction, now I have Data on the 1st switch. The other 3 have still the same problem, that the portX.rrd files are missing.
Edit: Nevermind, now all data showed up. -
wait a bit, they will come up, some data has to be downloaded at first what might take 10 - 15 mins.
Thanks everyone. I left it overnight running. Today I am able to see it appear. Just to be patient.
I have same issue ....
i have 'changed' the config of 2 switches from SNMPv1 to SNMPV3 but now the 2 sanswitches are not available in the left pane. Testing is OK
When running './lad.sh html' i see
SAN not in cfg : SANSWXXXX - skipped
SAN not in cfg : SANSWYYYY - skipped
any idea ?
upgrade to latest version (7.60) resolved my issue ... :)
