Problem with SSH connection
Hello Team,
I migrated the stor2rrd application from older RHEL 7.9 to 9.3.
All arrays such Dell/Hitachi/HPE woks properly.
I have a problem with connection to SVC/V7000, i've getting "connection closed" in error log and it's all :(
ERROR LOG:
Connection closed
Connection closed
Connection closed
Connection closed
Connection closed
Connection closed
Connection closed
Connection closed
Do you have any idea how i can debug what closing this connection?
stor2rrd version: 7.30
linux version: release 9.3 (Plow)
upgrade to the latest stor2rrd version, let us know if the problem persists
Dear Pavel,
I upgrade stor2rrd and i see this:
Error: Can't locate object method "new" via package "Net::OpenSSH" at /stor2rrd/stor2rrd/bin/SVC.pm line 2045.
Mon Jul 1 15:48:22 2024 - ERROR - svcconfig.pl: ERROR: Unable to connect to xxx
- Return code: 1
Mon Jul 1 15:48:22 2024 - ERROR - svcconfig.pl: ssh -v -i /home/stor2rrd/.ssh/id_rsa stor2rrd@xxx "lssystem"
- Return code: 1
I've found other issue with lenovo v3700 and newer stor version and i was check perl version:
[stor2rrd@xxx:stor2rrd stor2rrd]$ $PERL -MNet::OpenSSH -e 'print "Version: $Net::OpenSSH::VERSION\n"'
Version: 0.80
[stor2rrd@xxx:stor2rrd lib]$ more Xorux/Net/OpenSSH.pm
package Xorux::Net::OpenSSH;
our $VERSION = '0.83';
use strict;
use warnings;
[stor2rrd@xxx:stor2rrd lib]$ more Net/OpenSSH.pm
package Net::OpenSSH;
our $VERSION = '0.80';
use strict;
use warnings;
[stor2rrd@xxx:stor2rrd lib]$ perl -v
This is perl 5, version 32, subversion 1 (v5.32.1) built for x86_64-linux-thread-multi
(with 53 registered patches, see perl -V for more detail)
Compiled at Nov 27 2023 00:00:00
%ENV:
PERL="/usr/bin/perl"
PERL5LIB="/stor2rrd/stor2rrd/bin:/usr/lib64/perl5:/usr/share/perl5:/usr/lib64/perl5/vendor_perl:/stor2rrd/stor2rrd//lib:/stor2rrd/stor2rrd/lib"
@INC:
/usr/lib64/perl5
/usr/share/perl5
/usr/local/lib64/perl5/5.32
/usr/local/share/perl5/5.32
/usr/share/perl5/vendor_perl
/usr/lib64/perl5
/usr/share/perl5
The command lssystem works properly from error works properly. Other arrays works normally :)
So i'm thinking there is a problem with perl. I can't send you logs, because our policy lock any uploading package outside organization :(
Maybe you have any idea what i should check?
Dariusz
rpm -qa| grep -i openssh
[root@xxx:stor2rrd ~]# rpm -qa| grep -i openssh
openssh-8.7p1-38.el9.x86_64
openssh-clients-8.7p1-38.el9.x86_64
openssh-server-8.7p1-38.el9.x86_64
perl-Net-OpenSSH-0.82-3.el9.noarch
Maybe there is a option to replace a openssh.pm lib in stor2rrd?
Maybe it would be help?
remove this package: perl-Net-OpenSSH-0.82-3.el9.noarch
hereis inclyded 0.80 perl-Net-OpenSSH in lpar2rrd lib.
try connection test again
Still the same
[stor2rrd@xxx:stor2rrd stor2rrd]$ ./bin/config_check.sh V5030_TST
STORAGE: V5030_TST: SWIZ : sample rate: 300 seconds
TCP connection to "xxx" on port "22" is ok
. /stor2rrd/stor2rrd/etc/stor2rrd.cfg; /usr/bin/perl /stor2rrd/stor2rrd/bin/ssh_test_svc.pl xxx stor2rrd "" 30 "sshtest" XXXXX 0
Wed Jul 3 15:08:22 2024 - ERROR - ssh_test.pl: Unable to connect to remote machine xxx - Return code: 1
This must work without providing password:
ssh -v -o ConnectTimeout=80 -o StrictHostKeyChecking=no -o SendEnv=no -i /home/stor2rrd/.ssh/id_rsa_new stor2rrd@xxx"lscurrentuser"
connection failed!!
And output from command:
[stor2rrd@xxxx:stor2rrd stor2rrd]$ ssh -v -o ConnectTimeout=80 -o StrictHostKeyChecking=no -o SendEnv=no -i /home/stor2rrd/.ssh/id_rsa_new stor2rrd@xxx "lscurrentuser"
OpenSSH_8.7p1, OpenSSL 3.0.7 1 Nov 2022
debug1: Connecting to xxx [xxx] port 22.
debug1: fd 4 clearing O_NONBLOCK
debug1: Connection established.
debug1: identity file /home/stor2rrd/.ssh/id_rsa_new type 0
debug1: identity file /home/stor2rrd/.ssh/id_rsa_new-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_8.7
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.4
debug1: compat_banner: match: OpenSSH_7.4 pat OpenSSH_7.4* compat 0x04000006
debug1: Authenticating to xxx:22 as 'stor2rrd'
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts: No such file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts2: No such file or directory
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ecdsa-sha2-nistp521
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: curve25519-sha256 need=64 dh_need=64
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: SSH2_MSG_KEX_ECDH_REPLY received
debug1: Server host key: ecdsa-sha2-nistp521 SHA256:hm2ushaMZLJsTW9N96DI1U+YPM0uEKRbdKoJDHVDdXM
debug1: Host 'xxx' is known and matches the ECDSA host key.
debug1: Found key in /home/stor2rrd/.ssh/known_hosts:55
debug1: rekey out after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: rekey in after 134217728 blocks
debug1: Will attempt key: /home/stor2rrd/.ssh/id_rsa_new RSA SHA256:H/xxxx+8ZJO4 explicit
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<rsa-sha2-256,rsa-sha2-512>
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,password,keyboard-interactive
debug1: Next authentication method: publickey
debug1: Offering public key: /home/stor2rrd/.ssh/id_rsa_new RSA SHA256:H/xxxx+8ZJO4 explicit
debug1: Server accepts key: /home/stor2rrd/.ssh/id_rsa_new RSA SHA256:H/xxxx+8ZJO4 explicit
Authenticated to xxx ([xxx]:22) using "publickey".
debug1: pkcs11_del_provider: called, provider_id = (null)
debug1: channel 0: new [client-session]
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug1: pledge: filesystem full
debug1: client_input_global_request: rtype hostkeys-00@openssh.com want_reply 0
debug1: client_input_hostkeys: searching /home/stor2rrd/.ssh/known_hosts for xxx / (none)
debug1: client_input_hostkeys: searching /home/stor2rrd/.ssh/known_hosts2 for xxx / (none)
debug1: client_input_hostkeys: host key found matching a different name/address, skipping UserKnownHostsFile update
debug1: Remote: Adding to environment: SSH_LABEL_ID=2
debug1: Remote: Adding to environment: SSH_EPOCH=2
debug1: Sending environment.
debug1: Sending command: lscurrentuser
name stor2rrd
role Administrator
owner_id
owner_name
debug1: client_input_channel_req: channel 0 rtype exit-status reply 0
debug1: client_input_channel_req: channel 0 rtype eow@openssh.com reply 0
debug1: channel 0: free: client-session, nchannels 1
Transferred: sent 3628, received 3120 bytes, in 0.3 seconds
Bytes per second: sent 11012.1, received 9470.2
debug1: Exit status 0
send us logs
As i say few messages earlier:
" I can't send you logs, because our policy lock any uploading package outside organization :("
Our security locs all zips/tar/gz/etc. ;(
So thanks for trying to help me, i will try to found where is the problem. If i will find i will put to forum information :)
Have a good day!
Dariusz
are you at the latest stor2rrd version 7.90?
Yes. i downloaded from stor2rrd official web page - https://stor2rrd.com/download.php
Maybe the old configuration is blocking, this instance have few years...
it remember configuration from file ./etc/storage-list.cfg
i will try to remove one array (all data) and then try to add like a fresh array :)
Dariusz
not necessary, just upgrade
etc/storage-list.cfg is not being used
