Unmanaged IBM i LPAR not in Web Interface
Hi Guys,
first problem ever with lpar2rrd, i've got an unmanaged IBM i LPAR (no HMC) connected to a XORUX 7.80-1 Appliance.
The IBM i V7R4 LPAR was connected to another LPAR2RRD before, which we switched off.
On the new one, the LPAR does not show on the Interface. The Client states it's connected.
IF: C_SNDSTS - connection Established()
Also the Deamon on the Appliance seems to be active. (netstat)
I even see "data" of the LPAR in the lpar2rrd/data folder.
But when i run load.sh manually there is nothing about the System.
I even deleted the Lib on IBM i an did a fresh install. Nothing seems to be wrong, i don't now what the Problem is.
There were now problems visible in the Logs also.
Does anybody have an idea what i can check?
Thanks in advance!
Deamon.log:
[lpar2rrd@xorux logs]$ cat daemon.out
Fri Oct 20 14:00:13 2023: LPAR2RRD server (378538) waiting for client connections on 0.0.0.0:8162
<h1>Software error:</h1>
<pre>RRDp::end can only be called after RRDp::start at /home/lpar2rrd/lpar2rrd/bin/lpar2rrd-daemon.pl line 7564.
</pre>
<p>
For help, please send mail to this site's webmaster, giving this error message
and the time and date of the error.
</p>
Mon Jan 15 16:30:06 2024: LPAR2RRD server (378538) waiting for client connections on 0.0.0.0:8162
</pre>
<p>
</p>
Tue Jan 16 16:30:05 2024: LPAR2RRD server (378538) waiting for client connections on 0.0.0.0:8162
Tue Mar 19 09:10:47 2024: new server has been found and registered: 9009-41A*78108C0 (lpar=78-108C0)
Tue Mar 19 09:10:47 2024: mkdir : /home/lpar2rrd/lpar2rrd/data/9009-41A*78108C0/no_hmc/78-108C0--AS400--/
Tue Mar 19 09:10:47 2024: mkdir : /home/lpar2rrd/lpar2rrd/data/9009-41A*78108C0/no_hmc/78-108C0--AS400--/ASP/
Tue Mar 19 09:10:48 2024: mkdir : /home/lpar2rrd/lpar2rrd/data/9009-41A*78108C0/no_hmc/78-108C0--AS400--/DSK/
Tue Mar 19 09:10:48 2024: mkdir : /home/lpar2rrd/lpar2rrd/data/9009-41A*78108C0/no_hmc/78-108C0--AS400--/IFC/
Tue Mar 19 09:10:48 2024: mkdir : /home/lpar2rrd/lpar2rrd/data/9009-41A*78108C0/no_hmc/78-108C0--AS400--/JOB/
</pre>
<p>
</p>
Thu Mar 21 10:00:07 2024: LPAR2RRD server (378538) waiting for client connections on 0.0.0.0:8162
</pre>
<p>
</p>
Mon Mar 25 14:30:05 2024: LPAR2RRD server (378538) waiting for client connections on 0.0.0.0:8162
There are some old entrys, don't know if they are usefull...
send us logs and this output via the upload form (replace IBMi-name with name of your lpar
cd /home/lpar2rrd/lpar2rrd
ls -l data/IBMi-name--AS400--/
Done :)
