missing menu in IBM Power
hello,
I have two instances of lpar2rrd - 7.70 and 7.80-1.
In the old 7.70 I can see menu like RMCcheck CPU workload Estimateor, heatmap under IBM Power Systems:
It is missing in 7.80-1:
I dont see anything in 7.80-1 release notes that could cause that.
I cleared cache in webbrowser.
Could you please help here?
I am using containered version if it matters.
I would send you a latest version which fixes it but it is not on the docker hub, not sure what I can do now ... as I do not want to put it on docker huas, it is not the stable release
https://www.lpar2rrd.com/download-static/lpar2rrd-7.81-18.tar
OK, so this is a known bug? When the stable version can be released?
Is it possible to downgrade 7.81 -> 7.70 until new stable version would be released?
you can even upgrade manually in docker but it is not the right approach
no idea about next release , end of Q2
I just installed a new lpar2rrd for another customer and I found this error.
Menus are back now for IBM Power env. Thanks for the fix.
Is the fix included in 7.90 release?
yep, it is all fixed and included in v7.90
I have just updated lpar2rrd to 7.90, and now menu is duplicated (!).
I cleared cache on web browser and restarted lpar2rrd. Still the same, could you please advise?
hot fix: rm tmp/menu_vmware*; ./load.sh html
or upgrade to: https://www.lpar2rrd.com/download-tmp/mpibov/lpar2rrd-7.91-4.tar
