Latency
Hello team,
Is there any reason why in kubernetes charts for latency (node/pods...) are empty? - the same case is visible in your demo.
How to get latency charts for kubernetes?
thanks
Anyone?
please send the logs:
cd /home/lpar2rrd/lpar2rrd # or your LPAR2RRD working dir tar cvhf logs.tar logs tmp/*txt tmp/*json gzip -9 logs.tar
OK, I will provide logs soon, but as I wrote - the same case is in your Demo - https://demo.lpar2rrd.com/?menu=2817960&tab=6 -> Containers Latency tab.
Any findings? logs were uploaded March 25.
we will provide you a fix this week.
OK, thx.
Any update?
Any update?
we are collecting
'container_fs_io_time_seconds_total'from cadvisror. Description:"Cumulative count of seconds spent doing I/Os".We ran some IO workloads in containers and compared node sysstat data with cadvisor. It seems
'container_fs_io_time_seconds_total'is in nanoseconds rather than seconds.Fix is almost ready, we are testing it right now.
how is testing going?
IS the fix included in 7.90 release?
no, data provided by the kubernetes API is weird, or better, it is wrong as per us, it would have to be fixed on the kubernetes side
OK, but is there any action plan? current charts are unfortunately useless.
we know, but we do not know what to do, problem is not on our side, i.e. no any action plan
