Any way to export Power/AIX rPerf data in CSV or XLS format ?
is it possible to export AIX LPARs rPerf historical data in csv or some other format that can be used for further processing? CPU Workload Estimator just produces an image and that's it. I'd like to further analyse that data (for example separate prod from non-prod lpars etc ...) . Is it maybe possible to export data from XOROMON and import it into XORMON NG which does have additional features of exporting data ?
Nenad
- no, there is actually no option implemented for data export of CPU Workload estimator data
- Xormon NG: data exporyts are there easy, native rest api + option to export every graph into CSV via the icon on the grap.
- there will be data export/import possible from Xormon (lpar2rrd) to new Xormon NG (talking about IBM Power data), however not at the launch time in a few weeks.
