Lpar2rrd/Stor2rrd as docker using the same port
In the past I installed lpar2rrd and stor2rrd on the same linux OS using "legacy" method - installing rpm, configuring apache etc.
Recently I started lpar2rrd instance as a docker, I forwarded 80 port on host to 80 port on lpar2rrd container. It works fine.
But when I want to use stor2rrd on the same host, 80 port is already in use, therefore I cannot folow "legacy" approach where both applications are simply accessible from the same IP/Port - but suing different url /lpar2rrd and /stor2rrd.
I know I can start stor2rrd container with forwarding different port, but then I need to request extra port to be opened on firewall. Is there a better way of starting both lpar/stor as docker using the same port (80 in my case)?
I think the best solution for you will be some proxy server (container) running on port 80/443 and routing traffic between LPAR/STOR containers.
I'll do some testing and prepare brief howto for you.
- Create docker-compose.yml like this:
version: "3.7" services: caddy: image: caddy:latest restart: unless-stopped container_name: caddy ports: - "80:80" - "443:443" volumes: - ./Caddyfile:/etc/caddy/Caddyfile lpar2rrd: image: xorux/lpar2rrd restart: unless-stopped container_name: LPAR2RRD ports: - "8162:8162" volumes: - lpar2rrd:/home/lpar2rrd stor2rrd: image: xorux/stor2rrd restart: unless-stopped container_name: STOR2RRD volumes: - stor2rrd:/home/stor2rrd volumes: lpar2rrd: stor2rrd:
Adjust ports, volumes, names etc. to fit your environment
- In the same dir create Caddyfile like this:
{ auto_https off } localhost:80 { handle_path /lpar2rrd-cgi/* { rewrite * /lpar2rrd-cgi/{path} reverse_proxy lpar2rrd:80 } handle_path /lpar2rrd/* { reverse_proxy lpar2rrd:80 } handle_path /stor2rrd-cgi/* { rewrite * /stor2rrd-cgi/{path} reverse_proxy stor2rrd:80 } handle_path /stor2rrd/* { reverse_proxy stor2rrd:80 } }When you start all services with
docker-compose up -d, you can find both apps running on the same host at following urls:http://your_hostname/lpar2rrd/
http://your_hostname/stor2rrd/
