i faced issue with error
Send us logs.
loge has been updated
we would need to see some additional files:
cd /home/stor2rrd/stor2rrd # or where is your STOR2RRD working dir tar cvhf logs.tar tmp/LAN-totals/* gzip -9 logs.tar
Loge has been uploaded
su - lpar2rrd cd /home/stor2rrd/stor2rrd/data rm -rf 'Wrong Type (should be OCTET STRING): NULL' cd .. ./load.sh
Wait till the end.
After that refresh stor2rrd UI (ctrl+F5).
Let us know if that solved the issue.
Thank you. Issue solved. could you please tell me the Cause of the problem?
there was a switch with the name 'Wrong Type (should be OCTET STRING): NULL'.
It was probably caused by the wrong switch configuration.
As i saw in your logs, you have some not working switches in your configuration.
After applying the commands,!! How can it be removed (wrong type...)? In the SW tree, it does not appear
Hi Ahmed,
why are you using exclamation marks? Is there a reason for that?
Follow this docu, remove wrong switch 'Wrong Type (should be OCTET STRING): NULL':
I used why the wrong switch appeared after removing the SW by CLI!
switch must be removed from the more destinations as it is described in the docu i sent to you in the previous message.
I still do not see any reason to use exclamation marks...
Thank you, issue solved ????😋😎
