Problem acquisition CPU POOL HOST in HMC
Hi all,
I've installed an LPAR2RRD 7.50 server and I've configured it to acquire data from an HMC, rel > 9, by RestAPI.
The various HOSTS look like are acquired properly, but under the SERVER section in the GUI, where I have my IBM HOSTS, I'm able to only see the each LPARS but I'm not able to seen the CPU POOLS, memories etc etc about each hosts.
What am I doing wrong?
Have you guys any suggestions?
THANKS
what is your lpar2rrd server version?
my LPAR2RRD version is 7.50 and run on a Centos 8.5
Send us logs.
I've just send the log
Solved by SUPPORT
It was a GUI Problem
Here below the solution
>refresh the menu manually <
# cd /home/lpar2rrd/lpar2rrd; #or your LPAR2RRD dir
# rm tmp/menu*;
#./load.sh html
