Brocade Switch data not displayed in Web UI
Brocade Switch data not displayed in Web UI.
Please let me know if there is a way to resolve the error.
I updated the IP address in 'SAN device configuration' as the IP address of the Switch has changed.
I loaded the UI after a while, but an error is returned.
# ./load.sh html
Adding SAN port:
SAN not in cfg : devicename:xxxxx - skipped
Stor2rrd version is 7.2.
config_check.sh was OK.
- we support free users only on the latest product version, actually 7.40, download and upgrade
- is connection test working? UI --> settings --> SAN --> switch --> connection test
If it works and you cannot see it in the UI then send us logs
Thank you for your comment.
The connection test is working, but no data appears in the UI.
I have sent you the log.
Please check the log.
Upgrade to the latest version 7.40.
This issue should already be fixed there.
Let us know if the issue persists.
