9009-22 IBM power9 servers CPU charts missing after 7.40 upgrade
After upgrading to lpar2rrd 7.40, our two 9009-22A and 9009-22G IBM p9 servers are failing to show CPU charts in all of their LPARs and their dual VIOS servers. I checked the HMC for "sample_rate=60" which was still set. We are using the NMON method of sending data to the lpar2rrd RHEL7 server. Is this a bug?
can you upgrade to this version?
https://www.lpar2rrd.com/download-temp/lpar2rrd-7.42-10.tar
Let us know ...
The upgrade to 7.42 did not fix the problem. The server also does not show any total sections for all the LPARs like CPU,memory, overview, etc.
Send us logs.
tar cvhf logs.tar logs tmp/*txt tmp/*json tmp/hyperv_*
You might even attach screenshots when it helps in understanding of the issue.
The logs have been uploaded
Any updates for this problem?
I found the problem as there were too many HMCs configured for the free version(max 4). I deleted the decommissioned HMCs and re-ran the load.sh to get the CPU charts back.
There is still no server "Overview" section for these 9009-22 servers just an LPAR section.
The "Overview" section is working now, so the whole problem was too many HMC connections.
- 113 XorMon
- 169 LPAR2RRD
- 19 IBM i
- 139 STOR2RRD
