Connection to OracleDB using SSL/TLS
Hello Greg,
could you try connection test on the SSL only available DB with the patch below?
1. backup your current /home/lpar2rrd/lpar2rrd/bin/oracledb-test-api.pl file.
2. Apply this patch:
https://download.lpar2rrd.com/patch/7.30-1-4-g6e97f/oracledb-test-api.pl.gz
Gunzip it and copy to /home/lpar2rrd/lpar2rrd/bin (755, lpar2rrd owner)
-rwxrwxr-x 1 lpar2rrd lpar2rrd 9896 Jan 17 08:15 oracledb-test-api.pl
If your web browser gunzips it automatically then just rename it: mv oracledb-test-api.pl.gz oracledb-test-api.pl
Assure that file size is the same as on above example
3. try the connection test in web ui and let us know if it worked.
Hello damerva,
Thank you for fast answer.
TCP Connection test works for port 2484/tcp. But DB data test failed with: ORA-29024: Certificate validation failure.
I explored the topic in more detail and I think topic is more complicated then changing only protocol and port.
To use TCPS we need wallet with client certificate, trusted by server. It is defined in sqlnet.ora file.
So I think there are changes to be done:
1. Host definition: possibility to choice between TCP/TCPS protocol with default ports: 1521, 2484.
2. Host definition: path to file with sqlnet.ora when TCPS is selected.
3. Use collected data in sqlplus calls.
In my test environment, TNS you use is sufficient:"(DESCRIPTION=(ADDRESS=(PROTOCOL=TCPS)(HOST=oracle-host)(PORT=2484))(CONNECT_DATA=(SERVICE_NAME=service-name)))" @/path-to/lpar2rrd/oracledb-sql/Standalone_L.sql"<br>
If you want, I will be happy to do the tests after implementation.
Best regards, Greg -
Hello again,
Do you plan any implementation for this functionality?
Hello Greg,
so after you set up listener.ora and sqlnet.ora the connection test started working, is that correct?
