XIV crontab schedule for load_xivperf.sh
Using 7.2 version of stor2rrd.
There is a little confusion about the crontab entry for retrieving the XIV data.
When you run the connection test from the GUI and you still don't have the crontab entry, you get a warning message telling you to schedule load_xivperf.sh every 5 minutes.
But on the installation instructions, in the website IBM Monitoring: FlashSystem Storwize SVC XIV DS8K A9000 GPFS (stor2rrd.com), you are prompted to schedule it every 10 minutes -and definitely not less-.
Which scheduling should we use?
Thank you in advance,
lucas
lucas
Hi,use 10 minutes for XIV
XIV is not able to get all necessary data in 5 minutes.Well, it was the issue in the past, perhaps newer models are capacble to do it especially if there is no thousads of volumes.You can try even 5 minutes, you will see ...
Thx @Pavel
So, you use 10min for not overlapping the crontab calls to load_xivperf.sh, right?
I've tested it. In my environment (few hosts, few volumes) it ends in 5 seconds.
Therefore, I let it run every 5min the crontab.[stor2rrd@stor2rrd ~]$ time /home/stor2rrd/stor2rrd/load_xivperf.sh Waiting for 96972 real 0m5.383s user 0m2.909s sys 0m1.456s [stor2rrd@stor2rrd ~]$ _
Little off-topic question. The XIV is missing in the HEALTH STATUS page. Is that right? -
ok, then 5mins is fine.healt status is not available through SMI-S APi we use.or at least it was not available in the time we developed it.
Hi @Pavel,
Maybe they implemented it: Indication profile - IBM Documentation
AlertIndications are used to draw attention of subscribing client applications to the occurrence of an event. Lifecycle Indications are implemented in all XIV® CIM Agent releases. Beginning with XIV CIM Agent release 11.0, AlertIndications are implemented.
