HPE Nimble HF20 not visible
Hi all,
I onboarded on Stor2RRD v7.10-1 two HPE Nimbles HF20 configured in HA with Peer Persistence.
Nimble are visible on the UI under Capacity and Configuration subsection under the Reports section, but not under the Storage section.
Nimble configuration has be done as described at https://stor2rrd.com/HPE-3PAR-MSA-XP7-NIMBLE-StoreOnce-monitoring.php#NIMBLE
The config_check.sh works fine.
I'm also able to get information about pools, volume folders and volumes directly by CLI on Stor2RRD server (see below), but pool.cfg and volume_folder.cfg under data directory contains no data while data/VOLUMES directory contains nothing.
ssh -o ConnectTimeout=80 -o StrictHostKeyChecking=no -o PreferredAuthentications=publickey -o SendEnv=no lpar2rrd@XXX.XXX.XXX.XXX -p 22 "LC_ALL=en_US LANG=en_US LC_NUMERIC=en_US pool --list"
ssh -o ConnectTimeout=80 -o StrictHostKeyChecking=no -o PreferredAuthentications=publickey -o SendEnv=no lpar2rrd@XXX.XXX.XXX.XXX -p 22 "LC_ALL=en_US LANG=en_US LC_NUMERIC=en_US folder --list"
ssh -o ConnectTimeout=80 -o StrictHostKeyChecking=no -o PreferredAuthentications=publickey -o SendEnv=no lpar2rrd@XXX.XXX.XXX.XXX -p 22 "LC_ALL=en_US LANG=en_US LC_NUMERIC=en_US vol --list"
Thanks a lot and best regards.
Pool Capacity(MiB) Usage(MiB) Arrays
POOL-RACK-A-XXX 31524549 3800486 NIMBLE-A-YYYYY
POOL-RACK-B-XXX 31524549 3800649 NIMBLE-B-YYYYY
Path Description Agent Type Usage Limit(MiB)
POOL-RACK-A-XXX:/VOL-ST-RACK-A VOL-ST-RACK-A none Unlimited (31524549)
POOL-RACK-B-XXX:/VOL-ST-RACK-B VOL-ST-RACK-B none Unlimited (31524549)
Name Size Online Offline Usage Reserve % Limit % Path
(MiB) Reason (MiB)
Admin-From-A-to-B 2097152 Yes N/A 204204 0 100 POOL-RACK-A-XXX:/
Admin-From-A-to-B 2097152 Yes N/A 204204 0 100 POOL-RACK-B-XXX:/
CS1-From-A-to-B 5242880 Yes N/A 64965 0 100 POOL-RACK-A-XXX:/
CS1-From-A-to-B 5242880 Yes N/A 64965 0 100 POOL-RACK-B-XXX:/
Below the errors logged by load.sh script
ERROR : NIMBLE-A-XXX: Problem with configuration load, no VOLUME has been found, is there really exist one? : /home/lpar2rrd/stor2rrd/data/NIMBLE-A-XXX/config.html /home/lpar2rrd/stor2rrd/bin/LoadDataModule.pm:47064
ERROR : NIMBLE-A-XXX: Volumes cfg file has not been found : /home/lpar2rrd/stor2rrd/data/NIMBLE-A-XXX/VOLUME/volumes.cfg /home/lpar2rrd/stor2rrd/bin/storage.pl:20249
ERROR : Exiting NIMBLE-A-XXX as some core cfg file is missing: config.html || pool.cfg || volumes.cfg
ERROR : NIMBLE-B-XXX: Problem with configuration load, no VOLUME has been found, is there really exist one? : /home/lpar2rrd/stor2rrd/data/NIMBLE-B-XXX/config.html /home/lpar2rrd/stor2rrd/bin/LoadDataModule.pm:47064
ERROR : NIMBLE-B-XXX: Volumes cfg file has not been found : /home/lpar2rrd/stor2rrd/data/NIMBLE-B-XXX/VOLUME/volumes.cfg /home/lpar2rrd/stor2rrd/bin/storage.pl:20249
ERROR : Exiting NIMBLE-B-XXX as some core cfg file is missing: config.html || pool.cfg || volumes.cfg
Hi,Send us logs.Note a short problem description in the text field of the upload form.
Logs has been uploaded
Did you ever manage to resolve the issues?
Cause I'm see the same problems with my Nimble arrays. My Dell Compellent and Brocade switches are work just fine. -
Hi,what is your stor2rrd version?
7.30
