Power Server not shown
Hello.
I've found that all Power servers disappeared from "IBM Power Systems" menu. There is only "HMC Totals".
I suppose that this problem raised after planned works on a network. Network connectivity was lost during this procedure.
I've rebooted hmc, restarted load.sh, but no success. Still no servers in the menu.
I've checked load_hmc_rest_api* logs and did not find any problem.
Could you help me to resolve the issue.
lpar2rrd-7.10-1
do these files update regularly?
ls -l data/*/*/pool.rrm;
./load.sh html;
Some additions.After network outage it turned out that "Performance monitoring data collection" on hmc was disabled.I enabled "Performance monitoring data collection" and rebooted hmc.
Thank a lot!./load.sh html did the trick.All servers are available now.
This is probably the reason Powers disappeared from menu. You can either wait or run these commands after data collection is started again.
cd /home/lpar2rrd/lpar2rrd; #or LPAR2RRD dir
./load_hmc_rest_api.sh;
./load.sh html;
- 114 XorMon
- 171 LPAR2RRD
- 19 IBM i
- 140 STOR2RRD
