IBM Storage V7000 unreachable in stor2rrd after Code Upgrade of IBM (Level 8.4.0.2 (build 152.23.21)
Hello Xorus Team,
please explain below - trying to reach ourt from stor2rrd server to recently upgraded IBM Storage System (V7000).
Check does not work - if I pick out the commandline from check_script which is executed - it works passwordless.
Login via ssh commandline directly works.
But: Check asks for Password - why?
<snip>
[stor2rrd@machine stor2rrd]$ ./bin/config_check.sh XXXXXXX=========================
STORAGE: XXXXXX: SWIZ : sample rate: 600 seconds
TCP connection to "XXXXXXX.localhost.localdomain" on port "22" is ok
. /opt/stor2rrd/stor2rrd/etc/stor2rrd.cfg; /bin/perl /opt/stor2rrd/stor2rrd/bin/ssh_test_svc.pl XXXXXXX.localhost.localdomain stor2rrd "" 30 "sshtest" XXXXX 0
Permission denied (publickey,password,keyboard-interactive).
Error: Unable to connect to remote machine. unable to establish master SSH connection: master process exited unexpectedly
Thu Apr 22 08:57:44 2021 - ERROR - ssh_test.pl: Unable to connect to remote machine XXXXXXX.localhost.localdomain - Return code: 1
Password:
Machine Name: XXXXXXXXXMachine Type-Model: 2076-524
Machine Serial: XXXXXXX
Code Level: 8.4.0.2 (build 152.23.2102111856000)
Product Name: IBM Storwize V7000
[stor2rrd@machine stor2rrd]$ ssh XXXXXXXX
IBM_Storwize:XXXXXXX:stor2rrd>IBM_Storwize:XXXXXXX:stor2rrd>exit
Connection to XXXXXXX closed.
<snip>
Cheers,
ku
Hi,1. do you have defined an ssh identity file in storage properties? is not it DSA?2. you can try to switch to password authentification (latest stor2rrd 7.10+)
Regarding 1: yes - it's rsaRegarding 2: I'll give it a try and keep you posted.
My fault - dsa Keyfiles have been implemented - I switches to rsa and this works.Thnaks for you support.
