Problem with showing statistics in GUI from Power9 machines
for a long time I have problem with statistics from Power9 (I have no entry on GUI, but I have folders in data).
I upgrade to 7.10 and still the problem exists...
In error log I have:
I think everything is installed correctly:
It is on SLES 12 SP5.
Data ar collected:
Other statistics (from Power7 an Power8) are working.
Can anybody help me?
lpar2rrd@monitor:~/lpar2rrd/data> ls -la 9009-22A\**
lrwxrwxrwx 1 lpar2rrd users 39 Mar 15 09:25 9009-22A*XXXXXX -> /home/lpar2rrd/lpar2rrd/data/BASTET-HMC
lrwxrwxrwx 1 lpar2rrd users 39 Mar 15 09:25 9009-22A*YYYYYY -> /home/lpar2rrd/lpar2rrd/data/TRITON-HMC
Mon Mar 15 09:30:03 2021: Can't open /home/lpar2rrd/lpar2rrd/data/BASTET-HMC/hmc1.domain/cpu-pools-mapping.txt : No such file or directory/home/lpar2rrd/lpar2rrd/bin/lpar2rrd.pl:5255 : No such file or directory
Mon Mar 15 09:30:04 2021: Can't open /home/lpar2rrd/lpar2rrd/data/BASTET-HMC/hmc2.domain/cpu-pools-mapping.txt : No such file or directory/home/lpar2rrd/lpar2rrd/bin/lpar2rrd.pl:5255 : No such file or directory
Mon Mar 15 09:30:16 2021: Can't open /home/lpar2rrd/lpar2rrd/data/TRITON-HMC/hmc1.domain/cpu-pools-mapping.txt : No such file or directory/home/lpar2rrd/lpar2rrd/bin/lpar2rrd.pl:5255 : No such file or directory
Mon Mar 15 09:30:23 2021: Can't open /home/lpar2rrd/lpar2rrd/data/TRITON-HMC/hmc2.domain/cpu-pools-mapping.txt : No such file or directory/home/lpar2rrd/lpar2rrd/bin/lpar2rrd.pl:5255 : No such file or directory
lpar2rrd@monitor:~/lpar2rrd> $PERL bin/perl_modules_check.pl
lpar2rrd@monitor:~/lpar2rrd> perl /home/lpar2rrd/lpar2rrd/vmware-lib/apps/connect.pl --version
vSphere SDK for Perl version: 6.7.0
Script 'connect.pl' version: 1.0
lpar2rrd@monitor:~/lpar2rrd> $PERL -MLWP -e 'use LWP::Protocol::https; print "LWP Version: $LWP::VERSION\n"'
LWP Version: 6.05
Data ar collected:
lpar2rrd@monitor:~/lpar2rrd> ls data/BASTET-HMC/hmc1.domain/
EUROPA cpu.cfg-BASTET-VIOS1 cpu.cfg-HANAFWP1 cpu.cfg-TEST gui-change-state.txt
HANA1PW1 cpu.cfg-BASTET-VIOS2 cpu.cfg-HANAFWT1 cpu.html lpar.cfg
adapters cpu.cfg-EUROPA cpu.cfg-HANASLES15SP1 cpu.html-old lpars.col
config.cfg cpu.cfg-HANA1PW1 cpu.cfg-HANATEST1 cpu_mhz.txt mem.html
cpu.cfg cpu.cfg-HANAFWD1 cpu.cfg-SAPTST1DB2 gui-change-config.txt mem.html-old
Hi,send us logs if possibleNote a short problem description in the text field of the upload form.
I have uploaded logs.
In problem description I put links to this issue. -
enable utilization collection for the servers.
Utilization data collection is disabled for managed system : hmc1.domain:BASTET-HMC to enable it run :ssh hscroot@hmc1.domain "chlparutil -r config -m BASTET-HMC -s 60"--Utilization data collection is disabled for managed system : hmc2.domain:BASTET-HMC to enable it run :ssh hscroot@hmc2.domain "chlparutil -r config -m BASTET-HMC -s 60"--Utilization data collection is disabled for managed system : hmc1.domain:TRITON-HMC to enable it run :ssh hscroot@hmc1.domain "chlparutil -r config -m TRITON-HMC -s 60"--Utilization data collection is disabled for managed system : hmc2.domain:TRITON-HMC to enable it run :ssh hscroot@hmc2.domain "chlparutil -r config -m TRITON-HMC -s 60" -
Thanks, its work. I don't know why I forgot to enable it...
