Error Return Code:1 when run connection test add ibm v9000 storrd
Hi..
I Have this error when add storage IBM v9000 on storr2rrd when i connection test ifound this
SSH authorization: NOK
Tue Jan 12 15:25:10 2021 - ERROR - ssh_test.pl: Current version of Net::OpenSSH is 0.62. Use version 0.78 and higher.
Failed to add the host to the list of known hosts (/home/lpar2rrd/.ssh/known_hosts).
Received disconnect from IBMV9000 port 22:2: Too many authentication failures for stor2rrd
Authentication failed.
Error: Unable to connect to remote machine. unable to establish master SSH connection: master process exited unexpectedly
Tue Jan 12 15:25:10 2021 - ERROR - ssh_test.pl: Unable to connect to remote machine IBMV9000 - Return code: 1
I've searched the forums but haven't found a similar answer,.
can someone help me
thank
for SSH error
This solve my problemcd /home/stor2rrd/stor2rrd
. etc/stor2rrd.cfg
$PERL -MNet::OpenSSH -e 'print "Version: $Net::OpenSSH::VERSION\n"'
It shows:
Version: 0.62
I suppose there is installed module like this:
perl-Net-OpenSSH-0.62-1.el7.noarch
remove it by: rpm -e perl-Net-OpenSSH-0.62-1.el7.noarch
Then will be used module from /home/stor2rrd/str2rrd/lib/Net/OpenSSH which is newer.
Try connection test once more
and for
Failed to add the host to the list of known hosts (/home/lpar2rrd/.ssh/known_hosts) ERROR
i do
chown lpar2rrd /home/lpar2rrd/.ssh/known_hosts
chmod 600 /home/lpar2rrd/.ssh/id*
Thank to STOR2RRD support for the help
