SVC data will not determine
we have been using your application stor2rrd for a short time. After I have mastered some hurdles of the installation under Red Hat, I am slowly coming to the limit of my knowledge.
I'm trying a SVC to monitors. All the checks described in the forums and documentation are working fine.
However, for a SVC I get the error message
"svcconfig.pl: ERROR: Cannot get time from XML file /home/stor2rrd/stor2rrd/data/dehze01-svc001/svc.config.cron.xml_..."
SVC devices are 8 x dh8 nodes, with os version 7.8.1.8
No data is determined.
Can anyone help me or does anyone know the problem?
Hi,is connection test fine?su - stor2rrdcd /home/stor2rrd/stor2rrd./bin/config_check.sh dehze01-svc001
Thanks for the answer.The connection to the systems has been fine.
Rather there was a recusive stack overload in Perl.I solved the problem by slightly adjusting the stack parameters of Perl.
Now all values are displayed.
