PSU, patches info not filled
the SQL-Syntax for the PSU, patches info has an error:
SQL> prompt ##
prompt PSU, patches info
select to_char(action_time,'yyyy-mm-dd') "DATE",
patch_id,
version,
action,
status,
description
from sys.registry$sqlpatch
order by action_time;
SQL> PSU, patches info
SQL> SQL> 2 3 4 5 6 7 8 version,
ERROR at line 3:
ORA-00904: "VERSION": invalid identifier
patch_id,
version,
action,
status,
description
ERROR at line 3:
Name Null? Type
INSTALL_ID NOT NULL NUMBER
PATCH_ID NOT NULL NUMBER
PATCH_UID NOT NULL NUMBER
PATCH_TYPE NOT NULL VARCHAR2(10)
ACTION NOT NULL VARCHAR2(15)
STATUS NOT NULL VARCHAR2(25)
ACTION_TIME NOT NULL TIMESTAMP(6)
DESCRIPTION VARCHAR2(100)
LOGFILE NOT NULL VARCHAR2(500)
RU_LOGFILE VARCHAR2(500)
FLAGS VARCHAR2(10)
PATCH_DESCRIPTOR NOT NULL XMLTYPE
PATCH_DIRECTORY BLOB
SOURCE_VERSION VARCHAR2(15)
SOURCE_BUILD_DESCRIPTION VARCHAR2(80)
SOURCE_BUILD_TIMESTAMP TIMESTAMP(6)
TARGET_VERSION VARCHAR2(15)
TARGET_BUILD_DESCRIPTION VARCHAR2(80)
TARGET_BUILD_TIMESTAMP TIMESTAMP(6)
Maybe SOURCE_VERSION can be used?
Kind regards,
Frank
Update: This is obviously a change with Oracle 19c, because for 12c it works just fine.
Hello Frank,are you able to get version with this select? (on 19c)SELECT SOURCE_VERSION FROM sys.REGISTRY$SQLPATCH;Because I am unable to do so on 18c. Just want to check before we try to find a replacement.Regards,Daniel
Hi Daniel,I can query that column:SQL> SELECT SOURCE_VERSION FROM sys.REGISTRY$SQLPATCH;
SOURCE_VERSION
19.1.0.0.0Kind regards,Frank
