One of two VSP 5500H array not showing up in web interface
I have added two VSP 5500H arrays to stor2rrd. The config check shows that both are working. In the main health status I can see both arrays. However, there is nothing else for the one array. I have tried a manual load.sh as well as load.sh HTML but I cannot get the array to show up on the menu.
Send us logs.
You might even attach screenshots when it helps in understanding of the issue.
Thank you. I have submitted an upload with a description for G5K
