SAN Cisco NX-OS(tm) m9700 switches display port speed wrong way stor2rrd (2.71 )
SAN Cisco NX-OS(tm) m9700 switches display wrong port speed
stor2rrd (2.71 ) 2.70 was OK
Software (m9700-sf3ek9-mz), Version 8.4(1a)
stor2rrd ->
switch side
logs uploaded
Regards
tomlee
stor2rrd ->
| fc1-15 | END HOST | - | 21:00:34:80:0D:3C:80:68 | PROD (10) | 2000 Gbps | - | - | up |
switch side
-mds1a# show int fc1/15
fc1/15 is up
Port description is END HOST
Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
Port WWN is 20:0f:00:3a:9c:40:a0:00
Admin port mode is F, trunk mode is off
snmp link state traps are enabled
Port mode is F, FCID is 0x0b0020
Port vsan is 10
Admin Speed is auto max 32 Gbps
Operating Speed is 16 Gbps
logs uploaded
Regards
tomlee
Hi @tomlee,
you're right, there is a bug in 2.71 version. Use the following file as a fix.Gunzip it and copy to /home/stor2rrd/stor2rrd/bin (755, stor2rrd owner)-rwxr-xr-x 1 stor2rrd stor2rrd 123243 Apr 6 13:23 sanperf.plIf your web browser gunzips it automatically then just rename it: mv sanperf.pl.gz sanperf.pl
After deploying:cd /home/stor2rrd/stor2rrd # or where is your STOR2RRD working dir
rm tmp/*-conf-run
Configuration table should be refreshed till 10 minutes. Let us know, thanks. -
Great Thanks
issue resolved.
Regards
tomlee
