Problem with upgrade 6.16 :Can't locate VmwareDataWrapper.pm in @INC ...
We upgrade in the last version of lpar2rrd, but now we have this error in the web page:
Can't locate VmwareDataWrapper.pm in @INC (@INC contains: ../bin /home/lpar2rrd/lpar2rrd/bin /home/lpar2rrd/lpar2rrd/vmware-lib /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 /usr/lib64/perl5/vendor_perl /home/lpar2rrd/lpar2rrd/lib /usr/local/lib64/perl5 /usr/local/share/perl5 .) at ../bin/Xorux_lib.pm line 338. BEGIN failed--compilation aborted at ../bin/Xorux_lib.pm line 338. Compilation failed in require at ../bin/OVirtDataWrapper.pm line 11. BEGIN failed--compilation aborted at ../bin/OVirtDataWrapper.pm line 11. Compilation failed in require at /home/lpar2rrd/lpar2rrd/bin/genjson.pl line 3079. BEGIN failed--compilation aborted at /home/lpar2rrd/lpar2rrd/bin/genjson.pl line 3079. we also have this error in the load.sh: BEGIN failed--compilation aborted at /home/lpar2rrd/lpar2rrd/bin/LoadDataModule.pm line 6. Compilation failed in require at /home/lpar2rrd/lpar2rrd/bin/lpar2rrd.pl line 18. BEGIN failed--compilation aborted at /home/lpar2rrd/lpar2rrd/bin/lpar2rrd.pl line 18. nohup: ignoring input nohup: ignoring input Can't locate VmwareDataWrapper.pm in @INC (@INC contains: /home/lpar2rrd/lpar2rrd/bin /home/lpar2rrd/lpar2rrd/vmware-lib /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 /usr/lib64/perl5/vendor_perl /home/lpar2rrd/lpar2rrd/lib /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at /home/lpar2rrd/lpar2rrd/bin/Xorux_lib.pm line 338. any clue ? Regards Stéphane
Hi,ls -l /home/lpar2rrd/lpar2rrd/bin/VmwareDataWrapper.pm
[root@sproibmmut01 ~]# ls -l /home/lpar2rrd/lpar2rrd/bin/VmwareDataWrapper.pmls: cannot access /home/lpar2rrd/lpar2rrd/bin/VmwareDataWrapper.pm: No such file or directory[root@sproibmmut01 ~]#
md5sum lpar2rrd-6.16.tar
[root@sproibmmut01 lpar2rrd]# md5sum lpar2rrd-6.16.tarbd3421a864a10a31a3422f0f9adb7a8c lpar2rrd-6.16.tar[root@sproibmmut01 lpar2rrd]#
It is correct.can you run upgrade once more from command line?provide output.Do you have anough of space on the filesystem?Thenls -l /home/lpar2rrd/lpar2rrd/bin/VmwareDataWrapper.pm
Oh, i think I find the problem, my fs was full when I have done the untar, I untar it again and now it seems to work.
Thanks a lot for the help -
ok, it explains it
