lpar2rrd 6.15 VMware problem
I use the OVF solution and after upgrade from 6.11 to 6.15, VMware stopped working.
With the previous version everything was ok.
regards
below the error showing:
API host network connection: TCP connection to VCENTERNAME:443 is OK.
API authorization: API authorization to VCENTERNAME has failed!
Can't locate XML/LibXML.pm in @INC (@INC contains: /home/lpar2rrd/lpar2rrd/vmware-lib/apps/../ /usr/lib64/perl5/vendor_perl/5.16.3 /opt/freeware/lib/perl/5.16.3 /usr/opt/perl5/lib/site_perl/5.16.3 /usr/lib/perl5/vendor_perl/5.16.3 /home/lpar2rrd/lpar2rrd/bin /home/lpar2rrd/lpar2rrd/vmware-lib /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 /home/lpar2rrd/stor2rrd/lib /home/lpar2rrd/lpar2rrd/lib /usr/opt/perl5/lib/site_perl/5.8.8/aix-thread-multi /opt/freeware/lib/perl5/vendor_perl/5.8.8/ppc-thread-multi /usr/local/lib64/perl5 /usr/local/share/perl5 .) at /home/lpar2rrd/lpar2rrd/vmware-lib/apps/..//VMware/VICommon.pm line 11. BEGIN failed--compilation aborted at /home/lpar2rrd/lpar2rrd/vmware-lib/apps/..//VMware/VICommon.pm line 11. Compilation failed in require at /home/lpar2rrd/lpar2rrd/vmware-lib/apps/..//VMware/VIRuntime.pm line 15. Compilation failed in require at /home/lpar2rrd/lpar2rrd/vmware-lib/apps/connect.pl line 11. BEGIN failed--compilation aborted at /home/lpar2rrd/lpar2rrd/vmware-lib/apps/connect.pl line 11.
/home/lpar2rrd/lpar2rrd/logs/error.log-vmware
Can't locate XML/LibXML.pm in @INC (@INC contains: /usr/lib64/perl5/vendor_perl/5.16.3 /opt/freeware/lib/perl/5.16.3 /usr/opt/perl5/lib/site_perl/5.16.3 /usr/lib/perl5/vendor_perl/5.16.3 /usr/lib64/perl5/vendor_perl/5.16.3 /home/lpar2rrd/lpar2rrd/bin /home/lpar2rrd/lpar2rrd/vmware-lib /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 /home/lpar2rrd/stor2rrd/lib /home/lpar2rrd/lpar2rrd/lib /usr/opt/perl5/lib/site_perl/5.8.8/aix-thread-multi /opt/freeware/lib/perl5/vendor_perl/5.8.8/ppc-thread-multi /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at /home/lpar2rrd/lpar2rrd/vmware-lib/VMware/VICommon.pm line 11.
BEGIN failed--compilation aborted at /home/lpar2rrd/lpar2rrd/vmware-lib/VMware/VICommon.pm line 11.
Compilation failed in require at /home/lpar2rrd/lpar2rrd/vmware-lib/VMware/VIRuntime.pm line 15.
Compilation failed in require at /home/lpar2rrd/lpar2rrd/bin/vmw2rrd.pl line 22.
BEGIN failed--compilation aborted at /home/lpar2rrd/lpar2rrd/bin/vmw2rrd.pl line 22.
